Question about Alesis Sr 16 Stereo Drum Machine
Hi, my drum machine working,the only thing,i need a new box because is broken.....can i find only the box??
  • Alesis Master
  • 5,603 Answers
You will have to get case parts directely from Alesis.
http://www.alesis.com/store/index.php
Posted on Aug 06, 2010
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
Service manual
Open the box and try to spray a cleaning/lubricating solution inside the volume pot mechanism like Deoxit D5, you can also spray a little of it on the output connectors where you plugin your cable that runs to the amp. If that doesn't solve your problem you have to replace the volume potentiometer. The machine I have had similar issues and I was lucky to have a pot close in size and resistance value as the original which in my case was broken, so I just replaced it. Good luck!
Aug 07, 2013 | Alesis Sr 16 Stereo Drum Machine
I recently bought two Alesis Quadrasynth Plus Pianos, complete, but not funtioning correctly. One looks relatively new, but has a solid white screen and makes no sound when fired up. The other is visually...
Assuming you've tried rebooting the white screen one? If so, You need to take both to a qualified repair man and get the job done right. If you start swapping parts without knowing what works and what doesn't, you risk screwing up the good parts,
May 15, 2017 | Alesis Sr 16 Stereo Drum Machine
You can not play these drums live the spill of the fold back drum fill bin sets of the snare trigger ive turned down the sens on the red box still doesnt work a big waste of money i need to talk to...
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 11, 2011 | Pearl E-Pro Live Electronic Acoustic Drum...
The kick pad on my DTXpress II stopped working, and I have no idea how to troubleshoot (and am not eager to take it apart). I bought a new (used) one, and that doesn't work either. Thanks for any help!
First try connecting one of your other pads to the one for the kick. See if you can trigger the kick sound from it. IF you CANNOT, then there is a problem with that input OR the setting in the box.
These devices are NOT magic. They typically use a piezo disc sensor similar to those in some musical Christmas cards.(note that some of those now use small speakers.
the piezo discs can be caused to vibrate if an AC signal is applied, or they can generate a voltage when compressed.
IF the problem is in the kick trigger, you might as well CAREFULLY take it apart. You will probably find the disc is glued or was glued to the back of the rubber pad... The problem SHOULD be obvious as well as a solution... it will likely be broken gluing OR a broken wire... But do this ONLY if you veriify the problem is in the trigger and not the box input.
The trigger ONLY generate a voltage pulse of varying amplitude which then goes to the box which is where the sound is actually generated.
Apr 02, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Beringer xenyx 1204 repair
OFTEN the broken part CAN BE RETREIVED without removing the faceplate. There are MANY knobs and screws to remove to get at the jack AND then, the jack is mostly sealed and one cannot get into the innards of the jack.
I want you to try a few things before tearing into the unit. Here are ideas to try, not necessarily in prefered order as I can't see your unit and the broken part.
1. Take a very thin sheet metal screw and try to drive it GENTLY into the broken adapter. OFTEN you can snag the thing and drag it out.
2. Take a sewing machine needle and STAB the plastic insulator of the broken part and attempt to drag it out.
3. Attempt to epoxy glue a small dowel to the broken part. Use minimual glue so it doesn't squish out to the sides of the jack.
4. If the broken part is iron, try using a small rare earth magnet to **** the thing out.
5. If enough of the broken part is near the surface, attempt to solder a wire to it to use to extract the broken part.
6. Using a sewing machine needle and a soldering iron, melt the needle into the plastic insulator of the broken part.
I am sure one of these suggestions will work. The jacks themselves are sealed all the way around and you would have to unsolder the jack from the board. You would either replace the jack, or drill a hole in the bottom of some of them to be able to push out the broken part. All of this internal type work has risk to the unit if you are not equiped to do the work. If you can snag the thing with the above suggestions it will be quicker and safer.
Nov 28, 2009 | Behringer Music
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Oct 18, 2009 | Alesis Sr 16 Stereo Drum Machine
The drum machine will not power up
Try removing the batteries and running it off of an ac adapter with no batteries installed. Sometimes seriously flat batteries can keep a device from powering up.
Apr 30, 2009 | Alesis Sr 16 Stereo Drum Machine
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Alesis Sr 16 Stereo Drum Machine Logo
37 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
