Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Where is the power plug located - Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
  • 268 Answers
Here is a link that will show you where the power plug is located and much more about your machine. When you get to the page, look for the link on the right side of page and click to get to the download page. These guides have all the proper procedures with illustrations to help you.
http://safemanuals.com/user-guide-instructions-owner-manual/LEXMARK/X7170-_E
Good luck.
Posted on Aug 04, 2010
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
How do I set up my secura cam SW214-SCC
Step1: At the end of your SecurityCam cable you will find three colored plugs: Yellow(Video RCA), white(Audio RCA),Black/Orange(DC Power) or identify
OR
Identify the cables at the end of the SecurityCam cable as color for video ,audio and power may vary.
Step2: Plug Video RCA plug(1) into the "Video In" input(3)(Usually located at the back of your TV or VCR)
Step3: Plug the audio RCA plug(2) into the "Audio In" input(4)(Usually located at the back of your TV or VCR)
Step4: Connect DC power plug(5) at the end of your Security Cam into the end of the power adaptor(6)
Step5: Plug the power adaptor(7) into the main power point in your wall
Step:6 If you have AV/TV with RCA sockets you will need to switch the TV to the AV change to view the camera.
Pictures is attached. Please have a look at it.
Jul 17, 2016 | Office Equipment & Supplies
Fuse locations vizio e470vle
The fuse will be located on the power supply board. The power supply board is the one that the power cord plugs into. The fuse should be close to where the power cord plugs in at.
Dec 06, 2012 | Vizio E470VLE 47 Class Widescreen LCD HDTV
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
How do you get the password off of the
There are two ways to reset the boot or the bios password:
1.By removing the CMOS battery
You have to shut down the computer , disconnect the power plug and open up the unit and locate the CMOS battery ( which usually looks like a coin) . Carefully lift the battery out of its socket and set it aside.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
2. By using the motherboard jumper
Shut down your computer and disconnect the power plug. Identify where the jumpers are located. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. Then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down! Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.
For detailed instructions and snapshots u can check up this link :
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Mar 15, 2010 | Computers & Internet
Compaq presarios s5500uk wont boot up fitted new motherboard,pentium e5200 processor. existing hard drive ide seagate barracuda 7200.7 120 gbytes os windows xp
check the power supply: unplug the main connector from the motherboard,plug in the ac/mains power cord and switch on the on/off switch if any located on the power supply, locate the GREEN wire on the main connector that plugs on the motherboard, using a small length of wire insert one end into the plug where the GREEN wire is located and the other end into a BLACK wire on the connector. the power supply should power on if it is good: you will see and hear the fan turn on in the power supply. if it is good remove the wire and re-plug it.if it is not good replace the power supply. also check that the 110/220vac swithch is in the correct position for your mains voltage.do you have a floppy drive connected to the system? if so un-plug it and try again,re-check that you pluged the power button switch connector on the mainboard correctly,
Nov 19, 2009 | EliteGroup G31T-M7 Motherboard
I have one central vacuum location that does not receive power. All other locations work. I do get suction but just no power. What should I do first to test power to location.
You need to use a circiut tester (electrician test probe) on the two terminals the hose plugs in to to see if power is present to connect to. The receptacle likely has damage to the power connection from arcing from the hose previously not fully plugged in while using. You will most likely need to replace the wall hose receptacle.
Oct 16, 2009 | Hoover Powermax U5242-930 Vacuum
No picture no power red button flashes 4-5 times and shuts off
Try unplugging the 3 convergence yoke plugs and then trying to power on the set. The convergence plugs are located on the board on the left side of the tv looking in from the back and they are 3 identical plugs right next to each other they have a R B and G next to the plugs one letter for each plug just remember which plug goes to which location when you plug them back in.
Jul 16, 2008 | Philips 55P8341 55" Rear Projection...
Power Supply cord
The power cord plugs into the end of the connector that plugs into the PC.
Nov 04, 2007 | Proview PL456s 14" Flat Panel LCD Monitor
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
