Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John Deere Model 445 garden tractor. Replaced plastic cam shaft gear, tried to start motor and it backfires through carb. I just removed front cover of engine to check the timing marks on both the camshaft gear and the crank shaft, everything set properly. I did not change the valves settings. Not sure what to check next.
  • 3 more comments
  • Al Spiegelhalter
    Al Spiegelhalter Aug 04, 2010
    I would like for 'John' to look at this problem.
  • Al Spiegelhalter
    Al Spiegelhalter Aug 05, 2010
    OK, you think the distributor is out 180 degrees. I have looked for a distributor, but I am unable to locate one. I need more details on how to correct the timing.
  • Al Spiegelhalter
    John Deere 445 replaced camshaft, now backfires through the carb. it was suggested to rotate the camshaft. What drives the distributor? I see nothing on the camshaft that would drive the distributor. If there is nothing on the camshaft gear to change the timing of the distributor rotating the camshaft gear will do nothing. I realize the crankshaft turns serveral times before the camshaft makes one turn.
  • Al Spiegelhalter
    Al Spiegelhalter Aug 06, 2010
    Please read all of the other questions and solutions to my problem. When the expert asks how many cylinders there are, apparently does not have sufficent knowledge of the JD 445 garden tractor. I would appreciate someone that has knowledge of this tractor to answer my problem.
  • Al Spiegelhalter
    Al Spiegelhalter Aug 07, 2010
    I need help with my John Deere 445 - I need help from someone who knows about this engine.
  • 4,323 Answers
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
  • Al Spiegelhalter
    Do you know anything about the JD 445 engine?
    Problem Solver:
  • 3 Answers
Posted on Aug 06, 2010
  • 560 Answers
Does your tractor have points or is it electronic controlled ignition?
If points, replace them and the condenser, make sure the gap is correct as a too wide of a gap will make them open sooner--which advances your timing and could cause a carb backfire.
If electronic, check the timing position of your reluctor / pick-up coil as specs. illustrate.
I am assuming you are 100% sure of the cam/crank gear alignment. On some engines, it is possible to accidentally install the cam 180 degrees out if not careful.
Regardless, you have a ignition timing problem- too advanced, OR you have a sticky intake valve, or intake valve not seating properly allowing the combustion explosion to enter the intake or carb throat area.
  • 5,603 Answers
You MAY be timed 180 degrees out. Sometimes the timing marks also have to have the crank in a particular position OR the other possibility and more likely is the distributor has become 180 out. If you rotated the shafts while the gears were off, this is the most likely cause.
Posted on Aug 04, 2010
  • 2 more comments
  • Fred Yearian Aug 05, 2010
    The distributor will be where the ignition wires from the plugs go, but changing it 180 is often very hard..
    To correct the situation, I would remove the timing gear and rotate the cam shaft 360 degrees and re-install the gear to the timing marks.
    The distributor is often geared down with a 2:1 ratio which can result in a 180 degree timing error if the shaft has been rotated a full revolution before installing the gear..
  • Al Spiegelhalter
    Backfiring through the carb means the intake valves are NOT closed and there is a charge of fuel in the cylinder.
    One other thing is to check that the method of lining up the indexes is what the manufacturer specifies. I have seen some that do not line the indexes to eachother but offset them. This sounds like a gross mosalignment though. An insidious one would be if they changed the design and the marks are not right for your particular engine.
    How many cylinders does this have? If the engine uses magnetos from the flywheel a VERY common problem is that the keyway of the flywheel has sheared and the flywheel is now off timing for the magnetos. This happens OFTEN if the engine is subjected to a sudden load of a mower hitting an obstruction. In this case, one has to pull the flywheel and replace the shear key.
  • Al Spiegelhalter
  • 2,272 Answers
Check the fuel filter, check the spark plug, make sure the carburetor is not clogged  also clean  out the carburetor bowl. Also check is the plug is firing and the engine has compression.
take carb apart and soak it in carb cleaner for a few hours, then blow out every hole with carb cleaner .also check the gas cap.Remove it and clean it and replug it.the gas cap must be releasing pressure or blocking pressure.
also check the   flywheel key.
Check this.If its not helping then try this
John Deere  equipment engines have been equipped with carburetor anti-backfire solenoids to reduce the chance of engine backfire or "after bang" at shutdown.  This anti-backfire solenoid effectively reduces the possibility of backfire in most engines by stopping fuel flow to the carburetor when the key is turned off.  Some engines that still exhibit backfire at shutdown can see further reduction by putting the throttle at between ¼ and ¾ position prior to turning off the ignition.
After engine break in of 50 hours run time, the throttle position used may include moving the throttle to the idle setting without producing a backfire at shutdown.
If your unit does not have the anti-backfire solenoid, a different engine shutdown procedure will more likely give you better results.  Try moving the throttle to slow idle for 15 to 30 seconds, and then turn the engine off.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Al Spiegelhalter
  • 11,896 Answers
If the timing is set correctly the the carb may need to be adjusted. These are the two things that can and will cause backfire.
Posted on Aug 07, 2010
    Problem Solver:
  • 3 Answers
    Genius:
  • 1,040 Answers
Visit to the given link and buy the service manual. in 90% cases these manuals contains the information which can be repaired without the help of technician. If you are lucky then you will get the query solved...
http://www.gardenlawnmowers.info/?s=john+deere+445+wiring+diagram
Thanks....
  • Al Spiegelhalter
    This doesn't help me here and now.
I have a John Deere 425 riding tractor that sounds like it wants to start but wont actually fire
Is the engine being cranked by the starter but it won't fire? You say you're getting spark? You need air, fuel, spark, and compression to start so...
Pull the air filter and see if it is blocked.
Inspect the choke plate to see if it is working properly.
Are the plugs getting wet when you try to start?
Take the gas cap off the fuel tank and try to start.
Take the plugs out and move the wires where they can't ground. Stick your finger (thumb) in one plug hole and with the throttle wide open and no choke crank the engine. Is there compression? Try the other plug hole. A compression tester would be better than a finger or thumb.
No compression can be popped push rods or a cam problem among other things.
Aug 26, 2017 | John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Jul 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 245 lawn tractor will not start only backfires out the muffler.
There are 2 likely problems.
First spray a prime in the carb and see if the motor runs on a prime. If it does then you need to remove your carb and clean- there is likely water in your fuel.
Second- check for a sheared flywheel key.
Dec 28, 2009 | John Deere Garden
Cam shaft is not turning when i crank engine model 425 john deere
I'm guessing you have a 7-10 year old Kawasaki engine with the plastic cam gear, that is missing teeth.
Kawasaki has a service bulletin on this,they have changed to a steel gear. your Kawasaki or John Deere dealer will have that info.
Sep 19, 2009 | Garden
John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Aug 09, 2009 | Garden
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 445 tractor v twin 22 hp engine, john deere k series, no compression, removed valve covers and valves not moving, is there a timing chain, gear ?? or what drives the cam? Do you think the cam...
The cam has broken, this is a common problem with the 425/445. The cams are very cheap, made with plastic. Had mine replaced last year at the cost of about $300. Had water pump replaced as well.
Apr 01, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
2,404 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
