Please how reset my lexmark 342n photoconduct
    Champion:
  • 204 Answers
Usually you hold down me the power key and the paperfeed keys at the same time while plugging the power cord in. Hope this helps!!!
Posted on Aug 04, 2010
I need to setup a lexmark 342n on ubumtu can u help me please
Click on the link http://bit.ly/pG7RAN to see instructions on howto go about the procedure. For further assistance,please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark X342n All-In-One Laser Printer
84 Replace Photoconducter
Here's the link to the Lexmark website for instructions on how to install the photoconductor and resetting its page count on a Lexmark X340n. http://bit.ly/c66dvv. If 84 Replace Photoconducter message is still on the display after performing the steps, refer to this link on how to reset the photoconductor page count. http://bit.ly/bm3XBm. If all else fails, I suggest you contact Lexmark Technical Support for further assistance.
May 21, 2010 | Lexmark X340n All-In-One Laser Printer
995 engine error everytime we try and print
it is in reference to the photoconducter cartridge.
1. shut off power to printer. Pull your photoconducter unit out and check the position of the black marker located on the edge of the tranferbelt. I know one time I was fortunate enough to fix this error by rotating the photoconducter belt so that the marker was in a different position. Becareful not to touch the photoconducter belt (green shiny part) if at all posible. Reinstall the unit and power up.
2. If the above trick doesn't fix it after turning the printer off for a few minutes and you still get the same error when printing... You will have to replace the photoconducter unit.
tell me incase any issues
May 05, 2010 | Lexmark C510n Laser Printer
Light 1 and 4 continue to blink after photoconducter and toner changed
You need to reset the printer because it is not recognising the new conductor and cartridge. Turn off the printer
Hold the button (return) and power on
release the button when "Performing self test" is displayed
Select "Reset PC count" and press Select, the counter will Zero.
Hope it works!!! Shinal(FJ)
Mar 04, 2010 | Lexmark E250d Laser Printer
Lexmark C510 995 Service Engine Error: I can turn All four toner cartridge gears, but they all seem to turn quite hard by hand. Is that my problem?
2. If the above trick doesn't fix it after turning the printer off for a few minutes and you still get the same error when printing... You will have to replace the photoconducter unit. I wasn't as fortunate the second time I attempted the above trick and ended up having to order a new one. But hey its worth a try!!
Jan 30, 2010 | Lexmark C510 Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Jun 03, 2009 | Lexmark E350d Laser Printer
Need driver for lexmark 342n printer
follow this link and type your model number in the box -whether it be a E342 or X342, this will locate the driver for you to download, then select your operating system
http://support.lexmark.com/perl/support/support.cgi?ccs=37:1:0:0:0:0
May 16, 2009 | Lexmark X342n All-In-One Laser Printer
Error code Lexmark Optra 1275 Printer - 84 PC Missing
Usually there is more to this message particulary if this is a color printer. Basically the printer is telling you that tyhere is a problem in the Photoconducter area of the print cartridge. Normally I would expect to see a 84 PC end of life. Can you tell me if you left some information out, please?
Sep 03, 2008 | Lexmark Optra SC 1275 Laser Printer
161 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
