Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Bizhub 250: is the waste toner box at top of drum unit?
    President:
  • Konica Minolta Expert
  • 347 Answers
There is no waste toner box in bizhub 250/350.the thing which you are calling the waste box is not a waste box.that thing is "Toner Recycling".
Posted on Aug 21, 2010
How to replaced Developing unit of bizhub-C284e ?
POWER of the machine. Open the front door remove the waste toner box. Then the drum for the color you are replacing. Then remove the small cover behind where the waste toner box goes there are three screws assuming all are there. you should see a small circuit board trace out the wire assy for the developer unit you are replacing. Disconnect from the board. disengage the wire holder then with a screw drive remove the two screws holding the developer unit in one on top one on bottom behind drum release lever. DO not pull out bye the small tube!!!! may need to pry the unit out there is a guide pin on the top of next to the screw. Once cover the tube or the developer will spill out. replace the with new unit. Re-install via previous steps. When removing and installing both drum and developer unit remember the TRANSFER belt is above then scratch that and all the prints and copies will have the marks on them. Once installed. Conduct toner fill twice then gradation adjustment, in service mode
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 06, 2018 | Konica Minolta bizhub Office Equipment &...
Tip
Drum needs to be replaced message,Remove waste toner,Waste toner full
Save money by removing your drum units waste toner yourself.By removing waste toner the drum life will be increased.Remove the waste toner every 3 to 5 thousand prints.
The main cause of drum failure in this model is caused by waste toner build up at the back of the drum,this cause the drum cleaning blade to put more pressure on the drum and.
Slide the platte-ned cover Assembly to the left open the left cover,remove the drum and developing Assembly like you do when you have to remove a paper jam.The drum and developer assy is attached by 2 blue clips,unlock the clips and separate the def and drum.On top of the drum unit the is a plastic plug that you can remove and trough out the toner in a dustbin with plastic bag coverd.Do not use this toner again in the machine.
Reinstall the plug and connect the drum and developer unit with the two clips.Reinstall the unit.
By removing the waste toner regally you will save on service cost as well.
on Dec 05, 2009 | Canon ImageRUNNER 1670F Copier
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Call service 7410:0711657
Open top and front cover and remove Developer Unit. Next, open the left cover (at the waste toner box), remove waste toner box. Unlock the drum unit lock and then remove the drum unit. If the printer is dirty inside, clean it with vaccum cleaner. Be carefull with the drum surface, not to scratch it. Put the Drum Unit into a dark place if you remove the unit for a longer period of time. After you cleaned the printer inside, put the Drum Unit back. Dont forget to push the unit firmly, for good electrical contact. Put all the other components back and turn on the printer.
May 31, 2014 | Kyocera FS-2000D Laser Printer
C452 water toner
replace the waste toner box lower section below toner section is in front of the image units
Apr 30, 2014 | Konica Minolta Bizhub C452 Copier
Waiste toner box full.....how do I clean or change this? Looked through owners manual and can't find anything about it.
The waste toner sensor has detected
that the waste toner reservoir (drum unit)
is full.
FS 1128 has drum and developer as separate unit, waste toner gets collected in the drum unit . Right or left side of the drum unit has a cap fasted with screw, open it and remove the waste toner.Refix the drum and this will solve the probelm
Oct 08, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Bizhub 250 toner recycling
Toner recycling mechanism is located on the drum unit
The Cleaning Blade pressed up against the surface of the Photo Conductor scrapes residual toner off the surface. The toner is then conveyed by the Toner Conveying Rollers 1/2 to the Recycling Duct and eventually back to the Developer Mixing Chamber.Since the toner is thus recovered back to the Developer Mixing Chamber, there is no Waste Toner Bottle mounted in the machine.
Feb 23, 2012 | Minolta bizhub 250 Black and White Copier
Canon photocopier iR2016 displaying "waste toner full" on screen. How do I fix this?
Hi there you can empty the waste toner box wich is located inside drum unit.
The procedure is next:
open front cover and leftsideway door
release the blue handle above the drum unit
pull out the drum unit
on top of drum unit, near handle is located plastic grey colored cork
remove it and by means of vacume cleaner clean the vaste toner.
Note that if you flip out the drum unit and try to empty waste toner it could be messy and the toner can get into charge roller or on drum cleaning blade and then you need to change it completly.
hope that hepls
Aug 16, 2010 | Canon iR 2016i Black and White Copier
Toner fly in Bizhub 500
The problem may be comming from the drum unit, there is a small over sray tray right under the developer mag roller. It is mostly filled up with waste toner or dropped toner from the mag roller. You have to take out the drum unit and then the opc drum and vaccum out the tray and that should take care of the problem for now... The problem will come back..... Have you ever had the developer and or the drum & blade replaced. Minolta are a duel component copier. When the developer is worn out it will start to trow toner and fill up the small tray under the dev. mag roller..... Good Luck
Jan 18, 2009 | Office Equipment & Supplies
Kyocera Printer C5030N
Remove the developer and toner cartridge from the front of your unit. This will allow you to take out your drum where your waste toner box is. Once you have your drum with your waste toner box make sure to detach the waste toner box from the drum. Take a damp linen free cloth and wipe down the inside of the drum unit where your waste toner box goes in. Now take your waste toner box and make sure to secure the waste toner box really well to the drum. This has to be in very tight or else the printer will not think that there is a toner box attached the drum and this error will continue to appear. Important thing is to make sure that the toner box is attached really well to the drum unit.
Oct 18, 2008 | Kyocera Mita FS 3800 Laser Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
336 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
