Question about Sansui Televison & Video
I want to play movies from my laptop to my Sansui sv 2960 multi system tv. My laptop has a VGA plug. What cable do I need and to which plug on tv?
  • 149 Answers
I think like this
http://sewelldirect.com/pc-to-tv-adapter.asp
Posted on Aug 04, 2010
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
Sansui SV-2110K, Channel lock
Click here and try to download the user manual to your Sansui TV, and refer it how to make a factory reset to your tV. If it do not help you, the main system memory IC might be faulty, and should be replaced.
May 14, 2012 | Sansui Televison & Video
I wanted to know What do I need to play movies from my acer aspire 5315-2077 laptop right to my tv. what type of cords?
a vga cable- like you use for compute monitors. vga is your only video out on your laptop. most hdtvs have vga input.
Jun 27, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
I have a vga cable hooked to my sansui tv and to my laptop, but the tv just says "no signal". What do i need to do?
you may need to change the resolution of the desktop it may not be correct for the input that the tv needs. also look for any buttons on the laptop that will switch the video over to the VGA output. i suggest tryin around 600X800 and see if it will show up. good luck
Jan 07, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
PC video to Sansui
You probably need to tell your laptop to detect the second monitor, or somehow activate the video out function. How these things are done depends on your specific laptop model. Try looking in the user manual or on Dell's website page for your specific model of laptop.
Jun 30, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Televison & Video Logo
76 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
