Question about HP Office Equipment & Supplies
Product: HP PfficeJet 7410 All-In-One THe The Window On The Printer Control Panel Illuminates HP Invent Indicating The Unit Is Receiving Power, But The Print/Scan/Copy Functions Do Not Appear To Get Power. On Off Switch For Printer Does Not Light Up Indicating Power. How Can Part Of The Unit Be Receiving Power. An Alternate HP Power Adapter Was Utilized-Same Result. Any Help! William
  • wwestiii Aug 04, 2010
    Printer Power Issue! Advice Received Available From HP For Free Does Not Ientify Or Resolve Problem
  • 4,323 Answers
Hi
This issue seems to be with a blown fuse on main board or due to a disconnected ribbon cable inside the printer. Plesae trya power reset before checking for fuse or disconnected ribbon cables. Turn off the printer and unplug it for 10 seconds and then again turn it on. Hope ther were no power surges.
Reset procedure---
Unplug the power at the back of the printer and press # and "6" at the same time on the front panel
while holding these two buttons, replug the power at the back and keep holding till you see "semi full reset" on the screen
Now release the buttons and let the reset complete...you may be prompted to enter the language again etc....
Even if this does'not work...try a "full reset". Which is done by pressing "#" and "9" simultaneously with the same procedure
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 04, 2010
  • 1 more comment
    Daniel,
    Tried Both The Semi
  • Daniel Scott
    Daniel Scott Aug 05, 2010
    If the previous solution didn't helped you much then please follow these instructions. Check for a little metal clip within the cartridge holder that comes loose. When it does, it ends up puncturing/cutting the ribbon cable (or whatever it's called) that is needed to read/provide data to the cartridge. If you would remove the cartridges, you may see the ribbon cable attached at the back of the carriage. If the ribbon has any cuts then you’ll need to replace this ribbon cable. However, ribbon cable is not available separately, so you would be required Hope this helps... If it does please do not forget to accept the solution or post back for assistance.to order a new carriage.
    Daniel
  • Daniel Scott
    If the previous solution didn't help you much then please follow these instructions. Check for a little metal clip within the cartridge holder that comes loose. When it does, it ends up puncturing/cutting the ribbon cable (or whatever it's called) that is needed to read/provide data to the cartridge. If you would remove the cartridges, you may see the ribbon cable attached at the back of the carriage. If the ribbon has any cuts then you’ll need to replace this ribbon cable. However, ribbon cable is not available separately, so you would be required to order a new carriage.
    Daniel
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link….
http://h10025.www1.hp.com/ewfrf/wc/product?product=391194&lc=en&cc=us&dlc=en&lang=en&cc=us
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
    Utilized This HP Website For Free Yesterday, Also Spoke With HP Service Tech, Who Suggested Trying Alternate Power Adapter. No Resolution Or Identification Of Problem. Alternate Adapter Same Issue.
    Any Other Suggestions!
    This Printer Power Adapter Can Not Be Unplugged From The Power Block To Reset Per The HP Video. Power Source End Is Connected Directly To The Adapter Power Block. The Is Receiving Power Because The Wirless Window Illuminates Whe Plugged Into Power Source.
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 has power, screen is lit, but power button is not. None of the functions (print, copy, scan, etc. will work. Any ideas?
Seems like something a lot of us are experiencing. I have the exact same problem. Has anyone found a solution?
Dec 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 All-in-One Blue screen error message 00000020
I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 Display HP logo and Invent
Hello.
I'm afraid this one is a critical issue. If your product is in warranty or out of warranty , it would be better to upgrade to a newer model as this is a serious flaw in the printer.
all the best.
Sep 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
35 people viewed this question
Seeker5211
Seeker5211
