Question about Pioneer AVH-P5000D Car DVD Player
Hello, I have a pioneer avh 3100 dvd and everything is working exept for my usb, if il put my usb in it then my 3100 carradio will say N/A USB, if ill look on pioneers site whats the problem is then they say its not formatted in fat32, but i already format the usb stick in fat32 and it says it again. you know what it is?
  • Frank Heijmen
    Frank Heijmen Apr 22, 2012
    ill have the same problem with the n/a usb, i dont know what to do.my wire for my handbrake is already contacted to the earth.i still can check a dvd when im driving of something but i need to know what the usb problem is.
SOURCE: eject lock pioneer avh-p5000
Turn it off so you see the "demo" screen or the blank "off" screen, then hold eject + volume (mute) button down for few seconds to turn the eject lock off.
Posted on Oct 01, 2008
hogan doan
  • 227 Answers
SOURCE: pioneer avh-6400cd
Go to Pioneer site to down load the hardware manual for it, it should include the wiring diagram. Good luck.
Posted on Mar 23, 2008
  • 18 Answers
SOURCE: bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Posted on Jun 10, 2009
pumpkinman
  • 1165 Answers
SOURCE: i have a avh p5700dvd and when i put a cd in it reads error 02
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
Posted on Nov 07, 2009
SOURCE: AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
Posted on Aug 22, 2010
My pioneer avh-x7550bt doesnt read videos from USB
I have an avh x5500bhs which is similar to yours and you can only look at pics or music with the USB. It may work for videos but they would have to be in the right format
Sep 16, 2013 | Pioneer DEH-P6000 CD Player
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
Jan 11, 2013 | Car Audio & Video
I just had my pioneer AVH-P6300BT installed in my car and when i went to put a dvd in, the sound worked, but i couldnt see the movie. also i filled a USB with pictures i thought i could upload?
Just ground the parking brake wire (turquoise), get a TWO prong toggle switch. Splice it and connect each end to the toggle prongs. Every time you watch a video just toggle the switch on/off once and you will be able to see video.
Jun 15, 2011 | Pioneer AVHP7490DVD Car DVD Player
Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
Jul 15, 2010 | Pioneer AVH-P6500DVD Car DVD Player
How do i play video from usb on a Pioneer AVH-P4000DVD?
You can NOT view video using USB on this unit. Video has to come from the AV inputs (RCA connections) or from an IPOD connection. Sorry.
Jun 30, 2009 | Pioneer AVH-P4000DVD Monitor
Error 23 when I try to play music from my new flash drive
I have found that cruzer flash drives uses a special format with it's own software. I found a format utility to make it the FAT format for a friends cruzer..
May 23, 2009 | Pioneer AVH-P4000DVD Monitor
I might buy a pioneer avh p6400cd
hi there
this pioneer unit is just a CD player with a TV screen/monitor there is no DVD player in it. in order to watch a DVD you need to get the DVD player (sold separately) also its 6yrs old...it was really good in 2003 but since then there have been units that have a DVD,CD,navigation slot built in (this unit has a CD player built in only this means you cant put a DVD in the slot) if its selling for under $150 buy it if there asking over this i would wait and buy a newer system with everything just remember the DVD player for this unit is another cost so you may be paying just as much for this as you would for a newer unit........ so for me to answer your question its an OK unit and there haven't been to many problems with it except the complaints to pioneer about having to buy the DVD player separately........info for you in 2003 this avh-p6400cd sold for $499 but not to many people knew that they had to buy the units DVD player which was sold separately for $359
hope this has helped your deside
Mar 06, 2009 | Pioneer AVH-P6400CD Car DVD Player
Pioneer AVH-P5000D Car DVD Player Logo
342 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
