Question about Hotpoint Washing Machines
I have a hotpoint aquarius wf645 when i put it on a wash cycle it will fill for 1 minute then drain a message comes up F-o7 please help
Hold in the start and cancel buttons for 10 seconds, a "test on" message appears, hold in the start and cancel button again for 10 seconds and "test off" message appears, set your wash to whatever mode and it should work...it did for me!
Posted on Apr 27, 2008
I have a hotpoint aquarius WF32O and when i put
is it spinning and craccleking,,carbons faulty in motor ;;will work on spin but not lower voltage wash?
change carbons,, use genuines,only
Jun 21, 2010 | Washing Machines
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
WF745 Control PCB
Yon can puchase the part you need direct from Hotpoint, go to>
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on> SPARES.
Then click on the appropiate tab.
Hopefully, you will find the part you are looking for.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Hotpoint WF645 Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Jul 15, 2009 | Washing Machines
Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd420
Check if the hose from the tub to the drain area has come off; refit carefully. This could happen if the tub is unbalanced, happens sometimes.
Pl rate if helped..................
Dec 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
117 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
