Question about EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
Hi. I have a senao EOC 3220 Outdoor long range access point/bridge.
After configuring it, i can see the SSID on my Laptop but I can't connect to it. What could be the problem. The Firmware version is V 1.41. 05
  • Anonymous Mar 25, 2014
    i need firmware EOC-3610-1.0.1.02 , 2007/10/30
    Novelist:
  • 144 Answers
Hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Posted on May 07, 2008
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Problem using 2nd hand AP senao EOC3220 EXT
You can use this unit either as an access point, to provide wireless access to a network you already have, or as a bridge, to access a remote wireless network someone else has.
Note that you own the EXT model, meaning that you have to attach your own antenna to the connector before it will function. There is no internal antenna on this model.
Configuration instructions are available at
EOC-3220 Series User Manual
Factory reset instructions are available at:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
May 14, 2009 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
Can not log in to senao 3220
There are multiple issues here, and vague reports.
The original poster's problem could be caused by any number of configuration errors. Without him reporting his configuration, it would be impossible to diagnose this problem.
The April poster reports a non-problem, in that his PC's indication that his LAN is active means only that the device at the other end of his ethernet cable is communicating properly with his PC, but says nothing about whether access to the internet past that point is active or not. He reports other valid problems, such as difficulty understanding and performing the configuration process, but again much more detail is necessary in order to pursue his issue.
The March poster reports a symptom that implies that he has a bad cable, POE, or main unit (assuming that his PC ethernet port is known good). Swapping components to identify the faulty one is indicated here. I realize that an average user may not have more than one of some of these components, but someone will have to do this to identify the issue.
Feb 14, 2009 | EnGenius EOC-3220 (EOC3220)
My senao eoc-3220 is showing SSID as 802.11g-SSID. But it does not acquire an IP automatically. I tried using defaults but that does not work either. Trying factory reset does not work because the "#"...
Hi
I had the same problem. This may be as simple as pressing the enter button on your computer keyboard after all the activity stops. This brought up the number sign for me after which everything else in the reset procedure worked fine.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
I am using a EnGenius Senao 3220 plus bridge radio to pick up the signal from another same brand radio. i am able to connect to the network but i was not able to get in to the internet: "Unable to get...
If you have the radio configured as a bridge (not a bridge-router), you must ensure that your computer is in the same LAN IP subnet as the remote router. If the remote router supplies DHCP, this should happen automatically; if not, you must configure your computer manually.
Once there, you may have to manually define DNS servers on your computer in order to access machines on the internet by name. If you can browse to http://216.239.122.34, but not to http://google.com, your problem is solely lack of defined DNS servers. This is not an artifact of the Engenius units, but the remote server.
Oct 31, 2008 | EnGenius EOC-3220 (EOC3220)
Senao 3220 - access configuration info
I do not know what you have for a DHCP server but some DHCP servers will show you what devices have been given IP addresses which you can use that information to find what address it is at now. Other than that you can use the guess and check method just going through IP addresses until the page comes up, you can use network mapping software to scan your network to find it or you can reset the access point to factory defaults where it will have the default IP address that you can then connect to and re configure it the way you want it.
Jul 06, 2008 | Computers & Internet
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
I made firmware 1.39 to SENAO ECO3220
hey maick, I have the same proble, but I fix it, try this: 192.168.1.254, for me work fine, after that I reload the new firmware. now is working fine. good luck, jose luis Ogawa
Jan 19, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
370 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
