Cannon cp 660 Flashes "clean density sensor" on menu when ready. I also get a half inch thick horizontal line across the center of the page on every print which is like a grey smudgy line. Any help on problem indication would be much appreciated. Thank you Dean
SOURCE: Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Posted on May 15, 2008
alexdcd
  • 17 Answers
SOURCE: White lines in print
Does the printer have replaceable printing heads, or are they integral to the ink cartridge. If so they may need replacing or calibration. Another issue may be electronic contacts, check inside the printer and on the cartridges for any dirt or debris on the (usually copper colour) contacts on either end.
Also, if possible try the printer on an alternate computer to ensure it is not a problem with your software.
Kind regards, ACD
Posted on Jun 11, 2008
Tirzo
  • 94 Answers
Hi, since you've already try some basic trouble shooting to your printer such as head cleaning & ink cartridge replacement. There's a big possibility that the nozzle on that printer might be mis-aligned or clog by dried inks & contaminants. The possible solution that we can provide to you (asside from head cleaning) is printhead alignment. If issue still present after doing that solution, your printer may require service.
---->>> Tirzo
The Machine
  • 788 Answers
SOURCE: lines across printed pages
Does the line repeat, if so tell me what the distance it between repititions. I need the EXACT measurment in millimeters preferably but inches will do.
Posted on Oct 24, 2008
Printing 4 lines on every page
Check for dirty cartridge, if lines are across page in equal spacing about an inch and a half thick then cartridge should be replaced.
Oct 17, 2014 | HP Color LaserJet CP2025DN Printer
How to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Aug 04, 2014 | Stanley 77-720 Stud Sensor 200
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Lines across print
could be dust. try blowing the printer out and clean the thermal print head
Jan 16, 2013 | Mitsubishi Electric CP-3800DW Digital...
HP p2055dn has regular thick black lines running horizontally across each print out, four lines to a page, some lighter than others but the variation in density of the lines does not appear to run in a...
There will be a flap at the back that drops out and down to give access to the fuser for clearing jams and "straight through" printing. Four lines repeating down the page is equally likely to be be a mark on the cartridge drum, possibly from the Primary Charge Roller if the unit has been very hot or not used for a period of time in higher temperatures. Remove the toner cartridge and in LOW light manually rotate the drum using the gear at one end of the cylinder. Look for a scuff mark right across the drum or a black/grey line. You may be able to clean the drum with a cotton ball and alcohol. Try the print again and see if there is any improvement. If you have another cartridge in hand you might try that to verify cartridge or fuser.
Feb 12, 2018 | Office Equipment & Supplies
Lines across printed pages
I think you need a new cartridge.
Oct 24, 2008 | HP LaserJet 4 plus Printer
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Feb 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
56 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
