Question about Kyocera FS-4000DN Laser Printer
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
  • Kyocera Master
  • 525 Answers
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Posted on Feb 21, 2011
  • Anonymous Feb 21, 2011
    installed properly.
    normally.
    Causes:
I have a Kyocera FS-4000DN Ecosys. I replaced the toner and now I get this. error 7410:0106690. Does anybody know what this means?
7410 Drum unit non- installing error The drum unit is not installed or not installed properly. The drum PWB EEPROM does not communicate normally. The drum unit is not installed. Install the drum unit (See page P.1-5-10). Defective connection drum PWB (YC1) and connect-L PWB (YC3). Check the connection of connectors drum PWB (YC1) and connect-L PWB (YC3). (See page P.1-4-9, refer to figure 1-4-5) Defective drum PWB EEPROM. Replace the drum unit (See page P.1-5-10). Defective engine PWB. Replace the engine PWB
May 26, 2015 | Kyocera Office Equipment & Supplies
Call Service 7000: 0370082 Kyocera 4000dn
Toner motor lock error ,usuall ycaused by using non manufacturer toner ,you may need to get a new developer unit
Oct 14, 2013 | Kyocera FS-4000DN Laser Printer
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Jan 20, 2010 | Kyocera FS-4000DN Laser Printer
LCD Displays "Call Service 7410:0089745"
This is a Drum unit non-installing error: drum is not installed or not installed properly. The durm PWB EEPROM does not communicate nor mally. Defective connection drum PWB(YC1) and Connect-L PWB(YC3). Maybe defective drum PWB EEPROM or defective engine PWB or itis just the drum unit itself is defective.
May 22, 2009 | Kyocera FS-4000DN Laser Printer
Error code 0150:0008438
bad engine board... replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
May 14, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
Service call error
How do. replace the Rt. bush for the transfer roller have part but
having trouble removing and replacing it?
Chris
Feb 23, 2008 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer Logo
850 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
