Question about Watches
Safety chain broke off and where the watch fastens the small pin that goes between the strap fell out .Jeweler told me it's a screw in type and told me it had to go back to the company.
    Genius:
  • 1,970 Answers
Mcdevito75 here, Depending on the Maker of the watch, such as , Rolex, Tissot, Omega some parts are only available thru the dealer or maker of the watch, plus they also want to do the work. You can check and see if you have a Warrantee, if you do the work should be FREE if not greatly reuced in price.
Posted on Aug 04, 2010
The strap has pullrd out not broken how can i replace it
There should be a spring loaded pin that goes through the strap and into 2 holes in the watch. That is the normal way. If you have lost the pin, a jeweler will replace it.
Dec 26, 2017 | The Watches
How to adjust sekonda watch strap
There is usually a small wedge pin that needs to be removed...you can tap it out by using a small nail and a small hammer or wrench....remove the links and replace the wedge pin...if all else fails a jeweler usually will do this very inexpensively...hope this helps.
Nov 04, 2012 | Watches
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
How to change links in relic watch
Watch links are usually either pin type or screws. If you look at the side of each link where it connects to the next link you will be able to tell as a screw has a slot and a pin doesn't. It's most likely a pin and in that case, the cheap way to do it is by using a standard cork board push pin. If it's too difficult to do by hand, use a small hammer. If that doesn't work take it to a mall jeweler and have them do it for you. Usually charge $10. Ideally, there a is a special tool to remove link pins and you can get them online for cheap.
The screw types just require a really tiny precision screwdriver.
Nov 23, 2010 | Watches
I need a strap for my watch, because it broke. can anyone please help me?
Just about any watch shop or jeweler will have a nice selection of replacement straps in whatever style you prefer and they will typically install the new strap you buy from them at no extra charge.
Apr 23, 2010 | Calvin Klein k2151.20 Wrist Watch
I have been given a casio wave ceptor wvq 570 as a present. Unfortunately the plastic strap keeps detaching itself, by pulling the strap pin out. The strap seems undamaged but has a lot of play round the...
If the pin keeps coming out, then it seems likely that it is bent.
This can happen if the watch is fastened very tightly and your hand bends back until it strains the pin.
I suggest that you go to a jeweler and have a new one fitted.
Jan 12, 2010 | Casio Wave Ceptor Watch WVA105
Connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Mar 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
I would like to adjust my Pulsur watch strap but I cannot push those tiny screws on the strap
To do that you need a hardened steel pin and small hammer. Use that pin as a chisel and drive the bracelet pins out. Split pin end must come out first. When driving pins back in- blunt end goes in first and split end last.
You can make driving pin from hardened needle by blunting the pointed end.
Dec 17, 2008 | Watches
Resizing my watch
screw
small jeweler tools
take to jeweler for 5 bucks they will knock a link or 2 out for you
Jun 12, 2008 | Invicta Pro Diver 9745 Clip-on Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
