Question about Toys
How to fix the pressure on a red rider bb gun. The gun shoots and sounds like good pressure but the bb just goes out the end with no power.
3 Suggested Answers
  • 14 Answers
SOURCE: I have a daisy red rider bb gun that will not
The plunger spring may have broken, or perhaps the plunger itself has torn through (the rod may have pulled through the plunger head). It almost has to be one of the two. You'll have to either take it to a person who knows, or carefully remove the plunger assembly from the barrel and check it. Hope this helps (sorry to hear the gun won't shoot). :(
Posted on Aug 07, 2009
SOURCE: Daisy Red Ryder BB gun won't shoot
I just removed the jammed BB by sliding a cable tie into the sliver on top of the barrel just above where the wood ends and it popped out. Phew!!
Posted on Sep 05, 2009
Where can i purchase the threaded part that goes into the gun and punctures the co2 this is my second request
Direct, eBay possibly or direct from Daisy.
  • Daisy Outdoor Products - Official Site www.daisy.com CO2; Optics; Accessories; Collectibles; Info. ... Winchester Air Rifles ' Where to Buy ... © 2013 Daisy® Outdoor Products ...
  • daisy bb gun parts ' eBay www.ebay.ca > Search > daisy bb gun parts Find great deals on eBay for daisy bb gun parts and daisy ... Vintage Daisy Powerline Model 44 Co2 Innertube Nut BB Gun ... New listing DAISY AIR RIFLES AND BB GUNS ...
  • Air Gun Replacement Parts - AirGun Warehouse www.airgunwarehouseinc.com/repa.html Air Guns. Air Rifles; Air Pistols; BB Guns; ... Whether you are looking for Daisy BB gun parts or you ... we carry a wide range of air gun replacement parts that let ...
  • Apr 01, 2016 | Daisy BB Gun Pistol CO2 BB Gun Repeater...
    Daisy repair
    My Red Ryder B B gun is jammed-I have shot and shot it still no bb willcome out
    Jan 03, 2014 | Daisy Model Red Rider Rifle 1938 BB Guns...
    I just got my son a crosman 760 pumpmaster bb gun and we cant figure out how to shoot it. we loaded it, but for some reason it isn't shooting the bb's out
    Are you pumping the gun??? Once you have bb's in the gun you have to **** it and then pump the foregrip 10 times then pull the trigger.......
    Apr 24, 2011 | Sport & Outdoor - Others
    My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
    Good news, your engine runs
    But your pump may be bad
    Here's how to test your pump
    Check oil as outlined lower down
    Disconnect the washer hose and gun
    Connect water hose and turn on water and water should pass straight through the pump
    Look for clogs in the hose-end where water hose connects to machine
    Turn on machine and see if water shoots out pump
    If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
    Look for clogs in the end of each water connection.
    Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
    Finally, the gun trigger mechanism may be bad
    I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
    Check your pump oil
    Pump oil is SAE20 or SAE30 non-detergent motor oil
    Pump should be no more than 1/2 full of oil
    Use plastic hose to drain pump oil
    Do not turn machine on its side or turn machine over or engine oil will run into carburetor
    Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
    I have a daisy red rider bb gun that will not shoot. I put several bb's through it and it shot fine, but when I cocked it again it did not shoot. There is no tension on the spring when I try cocking again.
    Aug 03, 2009 | Daisy Toys
    My daisy buck 400 shot repeater bb gun wont shoot
    bazthespazz i would like that file you said, just bought the daisy buck 400 and got jammed arround the first 20 shots nd i want to repair it but its hard to remove the piece of the trigger
    Jul 30, 2009 | Toys
    1) **** the gun and look through the hole in the top, half way down the barrel.
    2) You should see a BB loaded into this area.
    - if no bb is present and you can see a circular magnet, then it is not loading.
    3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
    4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
    Apr 05, 2009 | Toys
    My daisy model 99 bb gun does not shoot bb's with any force.
    Try shooting a ton of silicone oil into the oil hole on the side of the barrel and then leave the gun sitting on its muzzle over night, then in the morning with the barrel out dry fire it a couple of times and then try it. what this does is expand the leather seal and bring back air pressure. it worked on my 99, good luck
    Mar 23, 2009 | Sport & Outdoor - Others
    Toys Logo
    82 people viewed this question
    Top Toys Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Toy Expert? Answer questions, earn points and help others
