Question about Toshiba Satellite Pro M15-S405 Notebook
My laptop (Toshiba Satellite Pro M70) freezes (a times, it gives a blue screen error) when I move it [or adjust its position]. Changed the Hard disk but the problem still persists.
Oh yes there is a tosh ins satellite M70 I have one
Posted on Jan 28, 2013
    Novelist:
    Champion:
  • 226 Answers
There's no M70 model, so I'm assuming you're talking abut a Satellite Pro M10, M15 series laptop. If the slightest movement hangs it or causes BSOD, then my guess is ... well ... I'll let you have it: the weaknesses of this models are: (1) bad memory socket (the upper socket),or (2) bad sound card socket. The one that's easiest to access is the upper memory socket - remove the installed memory from that socket, and see if your machine will still hang or blue-screen. I don't know if anyone still fixes these sockets (I do), but you can get around it by installing a larger capacity memory into the lower socket and skipping the upper socket altogether.
Posted on Mar 05, 2011
Toshiba sr3 laptop wont start
Access internet, download Symantec Power Eraser. Run program.
Problem is initiated before hard drive is recognized. Program is FREE!
Feb 26, 2014 | Toshiba SATELLITE PRO M70-SR3 LAPTOP LCD...
Toshibs sr3 bsod system wont boot up 0000007 fatal error is there a quick fix
You need to use the same as version/edition of your installed operating system (32/64 bit, Home/Pro/Enterprise) media to fix this problem.
The laptop has fallen on the floor while on and now it comes up with the error message error loading operating system
Disassemble the laptop and fit the Hard disk again or tightly.
If the problem is same ,think there are so many bad cluster or have been damaged ,and need to replace for another new .
I am giving the link for details ,just clck on the bellow link.
http://www.youtube.com/watch?v=jjXLR5yY7X4
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-1.htm
At the time dissemble use egg cortoon for placement the screw proper.
Hope this helps ,
Reply if you need farther instruction.
Feb 26, 2011 | Toshiba Satellite Pro L300 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          AS soon as I get past the log on screen my mouse freezes in the middle of my Laptop - Toshiba Satellite Pro 300
          next time tap f8 as you watch the bios screen load. this will allow you the option of booting into safe mode. see if you can get in through safemode to your computer. if you can then you have a software conflict somewhere. it could be a recent service pack added or a device driver that is not happy with the unit. if you get in through safemode go to your My Computer, right click and select properties. Select Tools and look for an option to check disk, select both check boxes and hit apply. it will tell you it needs to schedule the disk check. thats fine. now shut down your unit and let it run normally. it will scan the disk to see if you have a hard disk error and attempt to correct the corrupt areas. when this is all done see if you have any problems after that. if so let me know. there are about 4 other things it could be
          good luck!
          ruben
          Jul 18, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
          Toshiba Satellite 1800 Disk Drive Problem
          There's an issue with the way yout laptop is booting, either its set to the incorrect boot device or windows cant properly access the hard disk. Take it into a PC repair centre.
          May 17, 2009 | Toshiba Satellite 1800-S253 Notebook
          Toshiba satellite pro m70 screen problem
          try to connected it to a external monitor. and hit the "screen" (square box).
          Aug 15, 2008 | Toshiba Satellite 5005-S504 Notebook
          My screen wont display icons
          insert your WIN OS installation CD - But select recovery.
          Attempt to rebuild windows...
          This sounds like hard drive issue - sometimes a rebuild will temporarily get around this - but I would strongly recommend once running to do a surface / scan disk...
          Toshiba Satellite Pro M15-S405 Notebook Logo
          322 people viewed this question
          Top Toshiba Computers & Internet Experts
          pankaj rautela
          pankaj rautela
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
