Question about Tefal Avante Elite Programmable - 2 slices Toaster
Lever will not stay depressed - Tefal Avante Elite Programmable - 2 slices Toaster
  • 10,865 Answers
Hello. The first thing to try is to set the toasting level to a darker setting. Often this alone will solve the problem. If not, the mechanism which prevents burning or even a fire is simply worn out and it is time to buy a new toaster. J.
Posted on Aug 04, 2010
How can I fix? 2 slice toaster: cannot maintain lowered position to toast!
These are not repaired just replaced unless it is a commercial unit.
May 23, 2018 | Kitchen Appliances - Others
Why high beam headlights will not stay on ?
depressing the lever just turns on high beam momentarily. Keep on depressing until to you hear the switch "clicked" in to turn on and stay on. "De-clicking will turn it off.
Oct 19, 2014 | Cars & Trucks
The ice flap on my freezer will not stay open. If I reach up and grab the flap as it's opening, the ice will flow freely. But if I don't grab the flap and keep it open, the ice won't dispense. It's no
Kristen,
Thank you for giving more information. I believe you will need to replace the flapper on the ice dispenser. I based this answer on the following: you mentioned when the door is held open ice comes out. Let me know if this helps. As you may know, there are several different things that could cause this issue, but this is the most common one of them. Here is a how to video on this type of repair:
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Jul 21, 2014 | Frigidaire Refrigerators
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Parking brake light won't go off after releasing brake lever
Park brake lights normally operate by a small plunger type switch the turns off when the level or pedal is placed in the off position. Over time the spring in the lever weakens and placing the lever in the off position no longer depresses the switch. The switch can sometimes be adjusted to make better contact, or the switch bracket can be bent so the lever and switch make proper contact.
Feb 17, 2012 | 1992 Toyota Pickup
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
Jul 28, 2011 | Braun HT600 2-Slice Toaster
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
The handbreak indicator light on the dachboard of my passat 2.3 V5 tiptronic car is on despite the fact that the handbreak lever is down. what is the cause and how do I solve it?
there is a small switch at the base of the handbrake lever, if u pull the rubber boot back u will see it, the switch turns off when the little spring plunger is pushed down in that switch, many times the switch bracket gets bent and then the handbrake lever fails to depress the plunger and the light stays on check it, if u depress the switch with your finger and the light doesn't go out u may have a grounded wire to the switch, in that case u will need to pull the boot off to trace the wire and find the damaged section..
Jan 09, 2009 | 2000 Volkswagen Passat 4Motion
Tefal Avante Elite Programmable - 2 slices Toaster Logo
182 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
