Question about John Deere Garden
I have a John Deere backpack blower made by Echo (#PB4500) for well over 10 years and it worked like a charm. The other day while I was using it to clean off my driveway, the engine froze up. Couldn't budge the pull cord or move the fan blade at all. I took the engine covers off but couldn't see a problem (e.g., debris jammed in the blade). I then used penetrating oil and WD40 around all of the moving parts I could see (didn't take crankcase apart) and finally got blade to turn manually; although I did observe some friction in spots as the blade turned. I then tried to start the engine without success. The blade turned when I pulled the cord but the engine wouldn't start. Since the blower is very old, I thought that maybe the piston assembly would have to be rebuild or replaced. But, is it worth it?? Could it be something else?? Can I even find the parts??
Would you sell the blower as-is?
Doug-Wisconsin
Posted on Oct 20, 2010
  • 100 Answers
Depends whats wrong with it...remove muffler and check for scored or blackened piston...if this is the case cheaper to replace unit..
Posted on Aug 14, 2010
Echo leaf blower pb-261l part#10491011410 the part broke between the backpack and blower got the part off the backpack one is still in blower how to get that out
Take apart the blower and then re-assemble it according to the manual then you should be able to find and fix the problem.
May 18, 2017 | Echo Garden
Echo backpack blower bkue smoke
Sounds like mixture is too rich. Get correct mixture per manual and refuel.
Jul 11, 2014 | Echo Pb - 413t Backpack Blower
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
Echo blower wont start
ignition coil fixed my still backpack last fall
Apr 02, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Broken recoil starter rope on John Deere 5E Backpack blower. Is there an on line tech diagram showing assembly?
No, there isn't.
You have to take it apart, and make sure the spring doesn't get loose, or you'll have to rewind it. There's probably enough to just re-knot it if you're real lucky. Would it be for sale?
Mar 14, 2010 | Garden
What fuel mix do I use in an ECHO PB413H leaf blower
i have a leaf blower which uses leaded petrol but i would check your user manual and if you dont have one there allways is a copy of it online.
Nov 30, 2009 | Echo Inc. 44 CC, Carb Certified Backpack...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
What is the mix ratio for the troybilt 25cc blower?
Troy-Bilt products now are usually produced by Mtd, the ratio being 40:1.
However since John Deere made yours I'm 99.9% sure it should by 32:1.
In any case any power equipment you own (including Dolmar or Stihl) that takes an oill/gas mix benefits in the long run from using the richer 32:1 ratio. It protects the piston and cylinder much better, giving your equipment longer life. Do not use the "one mix for all" that you find at retail stores as it has been my experience it really isn't "one mix for all". Seen a lot of scratched pistons and broken rings from people using that.
Jun 17, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Apr 04, 2009 | Echo Garden
Garden Logo
618 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
