Question about Kenmore Refrigerators
I have a Kenmore Refrigerator model 106.60232900-Serial # EY 4912400 and when it is on the proper # set for the Freezer/Refrigerator ther is frost/dripping on a frosrree Refrigerator. I have changed the temperature gauge for the bottom because things would freeze,and after I put it back on the suggested # it now will not get very cold again after 2 days. The freezer is full of frost.
SOURCE: water freezing at bottom of freezer, food not freezing
Maybe a bad defrost timer
Posted on Dec 08, 2007
  • 17 Answers
SOURCE: hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Posted on Dec 10, 2007
  • 45 Answers
maybe? yeah but have you checked that the drainage hole is is clean and clear from any trapped dirt, that is sometimes a major problem, it stopped my freezer from functioning for weeks!! but the day i cleared it the water was gone, and the freezer was working as good as new!
Posted on Dec 22, 2007
  • 1073 Answers
SOURCE: Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Posted on Apr 21, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
I have a Kenmore household refridgerator/top freezer and it does not wok. The inside light comes on but other then that, nothing else happens. I switch the freezer setting to "OFF" and then turn it to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 13, 2010 | Kenmore 74889 / 74882 / 74884 Top Freezer...
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
May 30, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Noisy Evaporator Fan on a Kenmore model 596.76579600 refrigerator
The replacement evaporator fan for your model is a part number 12002744
Mar 15, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Kenmore freezer/fridge - freezer won't stay cold
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jan 25, 2009 | Kenmore Elite HE4 Electric Dryer
The refrigerator side of my kenmore refrigerator does not cool
Make sure the evaporator fan is operating. Since the fresh food side is cooled by the air flow from the freezer side. Check for blockage of the air duct from the freezer to the fresh food side. Set the temp control half way. Over adjusting this setting can cause problems with cooling. If I can help you any farther, let me know.
Nov 12, 2008 | Kenmore 53642 / 53644 Side by Side...
FRIGIDAIRE REFRIGERATOR
what line?
is the freezer cold?
model serial number?
May 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
112 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
