Question about Canon imageRUNNER 5000 Copier
What does the error code E000500-ff21 on a Canon imageRunner 5075 mean?
KyoDoc
  • 38 Answers
SOURCE: Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Posted on May 08, 2008
checkitright
  • 1362 Answers
SOURCE: E000001-0000 error code
usually on the canon e001 is a fuser problem,
1-thermofuse
2-thermistor (most likely)
3-fuser lamp
Posted on Aug 07, 2008
  • 35 Answers
SOURCE: ImageRunner 2230 Error E000001-0002
getfile.asp?rid=1258 August 31, 2007 getfile.asp?rid=3215 Product : imageRUNNER 2230 / 2270 / 2830 / 2870 / 3025 / 3030 / 3035 / 3045 / 3530 / 3570 / 4570 Title : E001 Error Code That is Not Resetable Error :
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on Nov 09, 2008
  • 168 Answers
SOURCE: error code E000732-0001 on canon imageRunner 3200n
this is a reader board error ... 1st check all connectors on the machine unplug and replug did this just happen or could there be a connector missing, this code usually comes from the connecter that looks like a small parrellel connector on rear going from scanner to right rear side
Posted on Dec 24, 2008
  • 6 Answers
SOURCE: scan to pdf on imagerunner 5075
Unfortunately, you can't do it remotely. You have to do it at the machine. Just hit the "additional functions" button, go into "communication settings", then "TX settings" on the left, then "edit standard send settings". This is where you would set your default resolution and file type.
Posted on Mar 17, 2009
E000004-0010 error on my canon ir 5075
That means induction heater is faulty (insufficient current) and needs to be replaced.
Dont forget to clear error log after the replacement.
(copier>fnction>err>clear)
Nov 03, 2015 | Canon ImageRunner 5075 Copier : IR 5075
How do i fix canon ir5075 copier tray 2 that is not working
Not sure what you mean by not working, inside the tray for paper size adjustment. Make sure that tray is adjust correctly. If one of the clips brakes off you might need a new tray.
Changing Paper Tray Size
May 09, 2015 | Canon Imagerunner 5075 Digital Copier
MY CANON 5075 TONNER SUPPLY MOTOR PROBLEM REGURALY I HAVE CHANGED MOTOR MANY TIMES BUT STILL IT GETTING PROBLEM WHAT IS THE PROBLEM
try to find the right toner for 5075 and replace it< if the problem still alive,so it's about your toner sensor
Oct 28, 2014 | Canon ImageRunner 5075 Copier : IR 5075
What does error Code e00030000 from Canon ir 5075 Mean?
I have come across :
E000 - The heater fails to heat
E003 - There is an error in the rise in temperature
Can you recheck the error message?
Aug 07, 2014 | Canon Office Equipment & Supplies
Error code E0014 in ir5075
its happen when the fuser motor not rotate, check the fixing roller ball bearing may be stuck
Dec 12, 2013 | Canon ImageRunner 5075 Copier : IR 5075
Error 001 004
reset the code first copier>function>clear>err>ok
then if problem is still there replace the thermistors and also verify if there is no paper in the rear connections of the fuser and the main frame
Oct 23, 2013 | Canon ImageRunner 5075 Copier : IR 5075
Error 100-001 mesin ir 5075
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Hope it helps.
Dec 18, 2012 | Canon ImageRunner 5075 Copier : IR 5075
E000500-0001
for ir 2016, the error code means that something goes wrong in communication between copier and finisher. Try to reconnect all connectors on finisher and on copier slots for finisher or the new finisher pcb is needed.
Hope that helps!
Jun 09, 2011 | Canon ImageRunner 2016 Copier
Scan to pdf on imagerunner 5075
Mar 11, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
727 people viewed this question
old marine
old marine
