Question about Lexmark X4650 InkJet Printer
Hello, My printer says that I have a paper jam but I can't find anything. I took all the paper out and put it in again. I turned the pirinter off and on. Nothing works. The page that originally got stuck, I got out and there was nothing torn off it..... Help!:)Thank you.
    Genius:
  • 1,087 Answers
Great job on taking out the paper jam without tearing it. Maybe the sensor got stuck and printer keeps thinking it's still has a paper jam. Remove the ink cartridges from the printer. Close the cover. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in the printer. When the printer's ready, reload the cartridges then close the cover. If this doesn't help, I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks
Posted on Aug 04, 2010
A piece of paper jammed up. I took the paper out but the alarm keeps on saying "Carriage jammed"
Hi there !
Check again your printer and maybe there is still paper jammed inside. Turn off your printer. Open the door cartridge and remove the cartridge. Check for paper jammed. After that return the cartridge and turn on your printer. Sometimes there is paper jammed inside that printer. Just press the power off and turn it on to roll over any paper jammed inside. Turning off on your printer also make your computer refresh the memory of your printer paper jammed.
To make hard reset of your printer. Turn off your printer and remove the power cable to your printer, leave it for five minutes and connect the plug and turn it on again. That will refresh the memory of your printer.
I hope it helps you.
Jan 25, 2011 | HP Officejet 7310 All-In-One Printer
How do i reset my canon PC-D450 laserjet printer after a paper jam?
Just open the cover from where you are putting your toner cartridges and the printer will start self test and will reset from paper jam.After the printer dosn`t find any paper it will try to print your last task.
Nov 09, 2010 | Canon 730i Laser Printer
Some paper got jammed, so I took it out. Now the
hi, Hello... I would like to try my hand at your problem (it sounds familiar and might be solvable). In a case like this, one has to treat a persistent paper jam assiduously: 1. Turn off the printer, and unplug it. Open up the printer completely, by all available hatches etc (-being that it's a laser printer, mind that too much exposure to bright light will spoil the bluish-reddish developer drum, so don't let light onto it more than a minute or so... or less preferably.) 2. Examine the path the paper takes, as it is printed, from the beginning (the paper tray, or sheet feeder, or manual feeder) to the end (the output tray), and all points in between. 3. Wherever there are bits of paper, or fluff, or anything like that, get it out of there! (-and of course, don't touch the drum - but you know that aleady.) 4. If there are any mechanical sensor switches, make sure they are not bent out of position or otherwise 'stuck on'... and if there are any optical sensors you can see, be extra sure there is nothing sticking in them (within the squared-off-U-shape most of them look like that), that would activate them. 5. Can't see anything? Reset your printer, as follows: Turn the printer OFF. (Or if it won't turn off, just) Unplug the printer from the wall or power strip. Leave it that way for 10 minutes. Plug it back in. Turn it on if it didn't turn itself on. Wait for it to initialize. Try printing again.
Jun 09, 2009 | Brother HL 2140 Laser Printer
Paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2009 | Brother DCP-330C All-In-One InkJet Printer
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
Printer says it's jammed, but i took out the paper tray, took out the jammed paper, put it back in, now it won't work. it continues to say it's jammed.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it
Apr 30, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon MF3240 Paper Jam - No Real Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
I have a hp deskjet d1341 printer
take off the back cover of printer and check it out for any paper left from the paper jam and then make sure you replace the back cover properly. : )
Oct 18, 2007 | HP Deskjet D1341 InkJet Printer
Lexmark X4650 InkJet Printer Logo
170 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
