Question about FixYa Service
Service suspension system light on - FixYa Service
  • 155 Answers
Hi Willie. Please repost this in the appropriate category in order to ensure that the right Experts can assist you. Thanks for using FixYa!
Posted on Aug 04, 2010
Suspension problems on 1998 cadillac sts
Best thing to do is have the OBD ( on-board diagnostics) system scanned for trouble codes. Places such as Auto Zone and Advance Auto may run a scan for free or for a low fee.
Mar 30, 2014 | 98-99 Cadillac Seville 32v North Air...
Air suspension hummer h2
Your vehicle is equip with air bag system. You probably experiencing an air lost due to air bags leaks or your leveling valve is exhausting air at the exhaust port. Here is what you do. Spray soap with water on spray bottle and spray around the air suspension area. when you see bubbles coming out that's the leaks. fix it. Good luck.
Nov 16, 2013 | Cars & Trucks
2007 Yukon Denali XL autoride suspension light comes on intermittently
Would need to know what DTC'S - diagnostic trouble codes are stored in the module for the autoride suspension . Hooking up a professional type scan tool ,looking at input data to the module etc... Looking at a wiring diagram an testing electrical circuit's using a DMM - digital multi-meter . Reading how the system works ,what all involved in making the system work . This is how a professional Tech would go about diagnosing this .
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling and loading conditions. The following components are involved in the operation of the ALC system:
• Air line tubing--Pressurized air from the ALC compressor is pumped to each of the rear shocks via air line tubing.
• Air drier--Pressurized air from the compressor is run through a drier containing a moisture absorbing chemical preventing water accumulation in the rear shocks.
• Compressor--Supplies pressurized air to the rear shocks
• Compressor motor relay--The relay supplies battery positive voltage to the ALC compressor motor.
• Pressure sensor--The electronic suspension control module (ESCM) module provides a 5-volt reference and low reference to the ALC pressure sensor. The module receives the signal voltage that is relative to the air pressure applied to the rear shocks.
• ESCM--Controls the ALC system and electronic suspension control (ESC) system and detects failures in both. The module monitors inputs from the position sensors, and pressure sensor to determine when to raise and lower the vehicle to trim height as the vehicle is loaded or unloaded. The module limits pump activation to 255 seconds to prevent thermal damage.
• Exhaust valve--An electric solenoid activated by the ESCM to vent air pressure from the rear shocks.
• Left and right rear suspension position sensors--The module provides a 5-volt reference and low reference to all 4 of the body-to-wheel suspension position sensors. The sensors send the ESCM a signal voltage that is relative to the rear suspension ride height
• Left and right rear shock absorbers with internal air chambers and dampers--Dampens the rear suspension and maintains trim height depending on the air pressure applied.
Nov 04, 2017 | 2007 GMC Yukon XL Denali
Ok susp light came on
A malfunction with the air suspension system has been detected
Start with the basics and check the switch in the right front passenger footwell , by the kick panel and see if the air suspension service switch has been turned off , or perhaps its fuse # 12 ( 15 amp ) for the air suspension switch , or fuse # 15 - 5 amp for the air suspension module ( but unless you have noticed other things not working it's probably not that fuse ) In the power distribution box in the engine compartment
( Ford states to disconnect your battery before servicing anything in the PD BOX ) fuse # 109 is a 50 amp maxi-fuse for the air suspension compressor , or it could be a sensor or the compressor itself etc.
Nov 14, 2011 | 1999 Ford Expedition
Service ride control light is on in a chevy 2003 2500
When the light comes on for the ride control it means that the system has detected a fault in the operation and the system needs to be scanned and tested for proper functionality. There are allot of faults that can turn the light on so the testing is very important to avoid replacing good parts and still not repair the problem. The most common fault is a leaking airbag at one or more wheels suspension. The life span of the suspension airbags (also called air springs) is about 100,000 miles
May 27, 2011 | 2003 Chevrolet Suburban
Service stability warning light is on
Thay means that your Stability Control System is malfunctioning. Your vehicle may be equipped with Continuously Variable Road Sensing Suspension (CVRSS) this system controls the ride height (Air Springs) and the stiffness (electronic shocks) of your suspension. Your computer data must be collected and used to help determine the cause of the failure before any repair can begin.
Jan 31, 2011 | 1998 Cadillac DeVille
The service suspension system light came on this today on my way to work. Is this still drivable and or should I head to the dealers? thanks Todd
Yes , it is drivable , check your milage and see if you are ready for an inspection. Sometimes these systems are set for a certain distance or time . If it is not , take it to be seen soon , could be air ride not leveling and will in some way affect the drivability !
Jan 27, 2011 | 2007 Chevrolet Tahoe
Check suspension?
Check suspension
Illuminates momentarily when the
ignition is turned to the ON
position and the engine is OFF.
The light also illuminates when the
air suspension system requires
servicing.
Nov 18, 2009 | 1998 Ford Expedition
Can I replace my F55 struts with Monroe Sensa trac
the system is integrated design and not a good idea to do this it may be possible but air system is designed to us magniride and will malfunction if changed
Oct 30, 2009 | 2003 Cadillac Seville
I have a 2002 caddy sts, service suspension sys
have the codes cleared but if there is an issue in the system it will come back on find out what codes are in the system
Jul 10, 2009 | 2002 Cadillac Sts
FixYa Service Logo
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Robin Hill
Robin Hill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
