Question about Canon PIXMA MX310 All-In-One Printer
What does document in ADF mean when you are trying to fax? It only transmit scanning of half a page
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
SOURCE: Canon PC 1080 F ADF Problem
call canon for instructions on how to clean feed roller and ADF path; otherwise probably need new seperator pad and possibly paper feed roller
Posted on Dec 19, 2008
  • 19 Answers
SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Posted on Jun 18, 2009
SOURCE: Document in ADF error when faxing
  1. This problem is caused by refilling your ink cartridge but there is a solution
  2. When the ink is low or the computer thinks the ink is low the sheet feeder will not work
  3. You will notice that the in use/memory light is on
  4. The memory has a report it needs to print but does not want to print it without ink
  5. To print the report anyway do the following:
  6. Press the <FAX> button to enter the Fax menu.
  7. Press the <Menu> button. [FAX SETTINGS] is displayed
  8. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  9. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK. Select Yes. make sure there is paper in the printer.
  10. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
Posted on Aug 13, 2009
SOURCE: Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Posted on Jul 10, 2010
Need instructions for sending a 10 page fax. I do not have a GETTING STARTED GUIDE. Is there a way to download a copy of the GUIDE? OR will you provide help?
Dear Joan
since the model was not mentioned its difficult to say but in most cases the fax is having a ADF (automatic document feeder). Few of then scan the face downward and other face upward.
test yourself by putting the document at ADF face upward and copy it, if copy comes as original, then put all 10 pages face upward in the ADF. press OHD(on hook dial) or SPK PHONE, dial the fax no. get the the fax Rx tone press START. Also you you can dial the fax no. and press start from memory.(as it will scan to memory and then fax).
Thanks.
Mar 17, 2015 | Office Equipment & Supplies
Xerox documate 752
Your document must be in place/position to be scanned, faxed, etc.
Place document, then scan. ADF is your automatic document feeder. Used when copying/scanning multiple pages. Reload and try again.
Aug 29, 2013 | Sewing Machines
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Dec 15, 2010 | Canon PIXMA MX310 All-In-One Printer
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jams when trying to fax or scan document
Check if the ADF backing is tucked under the the ADF frame. You can view here http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf steps 7 & 8 on page 155.
Apr 07, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Hp deskjet v40 printer set up
ADF means Automatic Document Feeder, used to copy, scan or fax multiple pages loaded at one time.
Aug 19, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
570 people viewed this question
old marine
old marine
