Question about Baby Lock Esante
Upper threads break,causing fabric to get caught in lower feed teeth.
    Problem Solver:
  • 11 Answers
Did you add oil to the parts of the sewing machine. This is important for the machines to run....my mom is an upholsterer...
Posted on Aug 04, 2010
Advance problem.
your foot pressure is too high.
lower the pressure as mentioned in your manual and you should be alright
Jul 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Instructions for threading
search on Google make, model,manual or threading instructions
Dec 07, 2015 | Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
Trying to quilt on my Hinterberg. First the thread kept breaking. Made some tension adjustments, now I am skipping stitches
possible problems
1) too thick for the feed dog to move the fabric forward need; lighter tension
2) are the upper and lower threads the same kind of thread?
3) is the thread feeding properly from above? sometimes the spool can snag the thread causing the tension to jump and skip stitches
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
I keep having trouble...I have tried some of the solutions on this page and still not working. I'm trying to sew on a very stretchy fabric, I have put in a fresh "ball point" needle, I have...
How frustrating for you - I will assume that "very stretchy fabric" would be lycra or a jersey with lycra or spandex in it. This can be tricky fabric to tackle on the sewing machine, especially if it is very light weight, textured or open weave. So use a Smetz "Stretch" needle, not just a regular ball point and a good quality polyester thread such as gutterman or metrosene. this link is great info on sewing threads, http://sewing.about.com/library/weekly/aa102100a.htm
tally_girl_20.jpg Use a stretch stitch that that has forwards and backwards movement to put elasticity into the seam. Use a teflon coated (black) sewing foot if you can get one, otherwise use a clear plastic foot. And if fabric is really hard to control, you can put strips of freezer paper between the two layers to give it some stability and help control the fabric when stitching. Use a spool cap over the thread spool to help the thread flow off smoothly. It is possible that your fabric may just be too difficult for a regular SM and best tackled with a serger with differential feed which is why sergers are so popular, they are great for knits.
However, your top thread breaking over and over like this sounds more like the top tension discs are malfunctioning or your top thread is caught/catching somewhere in the path to the needle.
So, take a deep breath, put in a regular woven needle and get the tensions sorted on cotton fabric scraps first. This way, you take the stretch fabric out of the equasion and establish if the machine is faulting.
Have you cleaned the top tension discs already? If not, do this now - turn to zero, then run the selvage edge of a clean piece of cotton scrap fabric between the discs in a sawing motion. Is there black gunk coming onto the fabric? Keep going until it is clean. Then rethread up and set tension back to 5. (I assume you are using a good quality thread and it isn't a very old spool that has been sitting around for years? Thread does dry out and get brittle with age - I keep mine in sealed containers away from sunlight).
Also carefully check the threading path from the spool to the needle, is the thread catching on a nick in the top of the spool? or some other part of your machine, is it wrapped twice around an eyelet or the thread takeup lever. Is there some sharp piece of plastic or metal that is causing the thread to break. Lower the pressure foot and pull the top thread just before the needle. It should feel firm but you should be able to pull it? If it breaks now, I would take it to the mechanic and get it serviced.
If you can pull the thread okay, then rethread the bobbin, set the tension back to the normal number on the bobbin holder, and test sew on cotton fabric. Can you get a good seam now? If thread is still breaking now, I'd take the machine to the mechanic for a full service.
Apr 14, 2011 | Sewing Machines
Lower thread breaking on lower looper ( green code) It won't sew over seams breaks everytime I rethread it
has the cone of thread at the back got caught up? this sounds like your thread is being caught and not feeding freely through the tension guides. Check the thread cones are okay and that the thread is pulling freely off the most right hand cone (lower looper). Also this thread dial should be set to the same tension setting as the next dial to the left for the top looper. Other possibility is that the tension disc itself has become gummed up or dirty with thread lint or dirt. Turn thread dial to zero and clean between the discs be rubbing the selvage edge of a piece of fabric between the discs gently. Now return tension to 5 or normal setting and try again.
Mar 28, 2011 | Janome MyLock 204D Mechanical Sewing...
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
My top thread gets caught in the bobbin. When I
Here are a couple of solutions to try.
* Try re-threading your machine. It may be threaded wrong.
If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will prevent them from getting caught in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
64 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
