Question about Samsung Televison & Video
What R the key/keys to press for transferring Desktop/Laptop Display to Samsung BN68-01201E LCD TV ?
5 Suggested Answers
SOURCE: Samsung LCD "keys locked"
push the menu button for 10 second on the tv.
Posted on Mar 05, 2008
aquif1990
  • 190 Answers
SOURCE: white display LCD TV
the connection of lcd panel is loose that is why display goes white,u hv to take it to the product care center
Posted on Mar 29, 2010
lovejoy91
  • 691 Answers
SOURCE: My 46" samsung lcd tv display keeps turning off
When it turns off, try flashlight 2 in from screen and see if you still see picture, if so then it's your inverter board is bad, you can price at shopjimmy.com or discount-merchant.com
Posted on Dec 18, 2010
  • 5531 Answers
SOURCE: Hi, When I connect my Samsung
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
Posted on Apr 22, 2011
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
Can't connect my HP G70-460 to my samsung tv
Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
Apr 01, 2012 | HP Computers & Internet
I need to connect my laptop to the LCD TV. Please tell me after connecting VGA with audio cable, what I should do on laptop to get the desktop details on TV Monitor? N.K.Makam
Hold the "fn" key and press the corresponding function key at the top to change the display. There should be a picture on the key that implies this function. For example, my compaq laptop uses the F4 key for this so i would press and hold "fn" then press and release F4.
Mar 05, 2011 | Proscan 32LB30QD 32 in. LCD TV
Set up TV as monitor for laptop with Fedora
Try pressing the function key and the monitor key (Fn+ F key). This will cycle through the display modes (Internal monitor, external display, or both). Your monitor key will look like one of the following: 5eab006.jpg009092c.jpg41a2ff0.jpgUsually after you reboot the default setting should be to run the internal display only. Your monitor could possible have gone out, possible the LCD panel or the backlight.
Jan 09, 2010 | HP Pavilion dv6000z Notebook
How can I connect my pc to tv
The DV6000 has all the drivers needed to connect to a TV as long as the TV has either a s-video connection or a pc vga input. The vga input is usually blue in color on the tv but on the laptop it may appear dark tan or brown and does not have screws to hold it into place, the plug just fits in and tension holds it in place. Once you connect the cables, change the input on the TV to the type of cable you are using. The laptop should automatically pick up the signal from the device and load the driver for it. The desktop should appear on the tv if the output signal and input are matched. The icons may appear different on the TV if the resolution is not close to a match but that should not be a concern unless it is cutting some of the picture off, in that case all you have to do is change the resolution to one that is easier for the tv to show. The dv6000 allows you to toggle through the video output settings by holding down the Fn key and tapping the F4 key, this will change the display to both laptop lcd and tv, just tv, just laptop lcd etc. It will even let you extend the desktop from the laptop to the tv or from the tv to the laptop, making one long display side to side.
Nov 28, 2009 | HP Pavilion dv6000z Notebook
Trying to connect hp pavilion laptop to tv with an s video cord but cannot get a visual on the tv
When the hardware connection is made: S video in laptop port and S-video in TV there remain two things to do.
1. On the computer, extend your desktop to show on the TV. On my laptop I press Fn-F5, and an OSD appears. I can choose the output to the TV and the internal LCD by holding the Fn key while pressing the F5 key. Each time I press the F5 key the focus moves to another icon (TV only, Monitor only, LCD and monitor, etc.)
Once you know how to externd the display or divert it to the external screen, you can take care of the TV.
On the TV remote (the easiest way), there must be a key labeled AV, AUX, or some such thing. Once you press it, and OSD appears on the TV screen giving you several input options :TV, AV, S-Video, PC. Select S-Video. It will tell you no signal if you have not yet diverted screen output of laptop to it.
Use the Fn-Fx key to send the signal to the TV.
This may not be the way to configure the connection for your laptop-TV combination, but I am venturing it anyway in the hope that it will help you solve the problem.
However there are no better sources of information than your laptop manual, and the TV user guide.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
Hooking up pc with computer and going into menu, setup on tv and the PC option is darkened and cannot select. why - isn't this the way to get the pc to work with the tv as monitor?
You may have to toggle the display outputs on your computer. If it is a laptop have a look along the f keys at the top of the keyboard. One of them should say crt/lcd or have a picture of a screen or a little square depending on the model of laptop. Hold down the fn (function) key and press this key and it should allow you to toggle between screens.
If this doesn't work, or if it is not a laptop machine, try clicking the right mouse button on the desktop and selecting either "Nvidia Control Panel" or "ATI Catalyst Control" depending on the machine. In there you will find the option to switch on your external display.
Jul 18, 2009 | Samsung LN-T4665F 46 in. LCD Television
Wanting to use tv as monitor with benq a52 v03 joybook
Yes, you need to press the key combination for your laptop to direct the video output through the external VGA port. It varies by laptop, but it usually involves the use of the Function (Fn) key and another key like F4...look for a picture of a screen in the same color as your function key.
Jun 15, 2009 | Computers & Internet
Not transfering display but can't see whats going on.
Power up the monitor first then the laptop and the video will switch automatically to the monitor.
The other way, when the laptop is powered up press the Fn key + F4 key, This toggles the video output between the LCD and the external video connector.
Apr 13, 2009 | HP Compaq Presario V2000 Notebook
Display my laptop on my tv
You can't connect a standard TV to a computer using a VGA cable. If you have it, use the composite (yellow) RCA jack or S-Video from your laptop. As for turning off a laptop monitor, look on the function keys for LCD/CRT or icon for monitor (typically 3, 5, 7, or 8) hold down FN key and press the correct function key.
Jan 13, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
