Question about Baxter Ovens
Baxter oven ov210g-m2b 1994 has been on all morning creeping up to 71 degrees at 11:00, pressure washed walls this weekend, tried to cover every thing. Cathy 216-991-7500. Any local repair suggestions?
2 Suggested Answers
  • 245 Answers
SOURCE: oven not lighting
replace the ignitor. these will get a hairline crack in them and will not show proper resistance to allow the valve to turn on and let gas start flowing.
Posted on Jun 24, 2009
Baxter oven not working
Hobart owns Baxter. You'll have to call Hobart.
Feb 14, 2014 | Baxter Ovens
Backfire
possible bad ignter .The glow or spark may not be hot enough for the electronics to to realize it's trying to lite.problem related to ignition and or ignition control module.ask your parts dealer about these parts.
Jul 28, 2013 | Baxter Ovens
My oven is loosing temperature
To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
Feb 10, 2012 | Ovens
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
Were is located the thermostate
The thermostat is solid state, it is incorporated into the control board. You can however locate the temperature probe which goes into the left side of the back of the control board and goes into the top of the oven under a cover near the air pressure switch and high limit thermostat. To locate follow the small aluminum tube coming from your exhaust stack, that will lead you to the air switch which is next to where the temperature probe enters the heat exchanger compartment.
Oct 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Oven not lighting
Jun 24, 2009 | Ovens
Oven with an attitude
Check the lineator actuator motor. If you remove the top cover there should be a strip of metal stuck on the cover to put pressure on the gear to keep it from free wheeling down. These is a tiny button/nipple that sits in the hole in the top of the gear shaft. Lose it and you're sunk. Work with good light and watch the grease. Good luck
Feb 27, 2009 | Baxter Ovens
Ovens Logo
104 people viewed this question
Top Baxter Ovens Experts
Marvin
Marvin
Lawrence Oravetz
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
