Question about Plantronics Discovery 925 Bluetooth Headset
Mic no longer works. - Plantronics Discovery 925 Bluetooth Headset
    Brigadier General:
  • 3,006 Answers
Unless it's under warranty there is no fix and it must be replaced. There is nothing serviceable inside and no spare parts are available: Plantronics service centres just test them and replace the entire unit if faulty.
Posted on Aug 04, 2010
My Behringer PMP1280S INPUT Chanel 1 is no longer working, after pulling out the mic XLR plug whilst the amp was still turned on.
You should be able to unplug a mic from the xlr input with the unit on with no problem.
I beleive the problem is that the xlr input jack has one or more legs broken off the board. If you dsassemble the board and resolder the three legs to the board you'll probably fix the problem.
Dec 01, 2015 | Behringer Music
BUILT IN MIC WILL NOR WORK, but was ?
Have you tried system restore to a period when your MIC worked just fine and see if this helps?
Oct 06, 2017 | Apple Isight Web Camera M8817ll/a
Mic is not working
Hello there,
If the mic of the phone is no longer working, then it means the phone might have fallen hard or hit a hard object or fallen in water and have disconnected the mic from the main board hereby causing the mic not to work again.
The solution is to get the phone disassembled and remove the mic there and replace it with a new mic.
Before doing so, you can use an external earpiece for the main time, that allows easy access to calling out and receiving easily. Or you can use a bluetooth handsfree on the phone before you go for the mic replacement.
Be sure to have a professional replace the mic for you because replacing it could be very sensitive.
Check the volume control of the phone also, to be sure that the volume is no too low or turned off, hereby causing your other recipients not to hear you.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Samsung S5620 Cell Phone
Motorola mic no longer works. Any fixes?
This is probably a broken wire inside. the microphone piece moves back and forth to turn this unit off and on and the wires have broken because of it. there is a similiar problem with the H800 as the mic extends in and out to turn it on and off.
Nov 07, 2009 | Motorola Mobility H710 Bluetooth Headset
I have a MXL 990 studio mic which I recorded one no longerworks
Are you using the original cable for the mike? In order to use phantom power the XLR connectors have to be wired in balanced configuration. Pins 1,2 and 3 must be wired separately. If you use a cable with 1and 3 connected you could damage the phantom power supply and in some cases the microphone.
Aug 19, 2009 | Marshall MXL990 Professional Microphone
My mic stopped working all of a sudden. i had
make sure its completly pluged in it may have came loose. or mae sure none of the drivers changed.
Jun 04, 2009 | Gateway CX2610 Notebook
Using Skype - Intneral mic no longer works
Its due to your internal laptop MIC's failure! Plz check at any Compaq Service station! Becoz its internal hardware error! Becoz there r no seperate drivers for MIC! If your speakers are working great then MIC should work or else try to get repaired it!
Dec 02, 2007 | HP Compaq Presario V2000 Notebook
How to use mic on webcam?
same problem I can hear my contact but they casn't hear me
Oct 29, 2007 | Logitech Webcam
Sound
if it has a external mic jack you could see if that is working. if it is then the mic on the camcorder is bad.
Sep 15, 2007 | Panasonic VHS-C PV-L354 Camcorder
Mic not working
open it and look for any tiny, broken wires
Jun 04, 2007 | Yamaha MC-7 Professional Microphone
Plantronics Discovery 925 Bluetooth Headset Logo
95 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
