Question about White Sewing Sewing Machines
Reassemble bobbin and thread parts because now clumps up stitches multiple on bottom and only a couple on top. can't find my manual for my white 658-31495 machine please help pretty sure it boils down to proper threading
    Problem Solver:
  • 11 Answers
You have to try to play with it. take a piece of material and try setting up the correct stitch. It may be old threat too. did you check to see how it was threaded in the bobbin pin. it must be clean.
Posted on Aug 04, 2010
Bottom thread seems too tight!!! Help!!!
If the bottom thread is tight there should also be loops on top and this means that the upper tension is too tight.
Get out your manual (http://www.singerco.com/uploads/download/1198_8763-efs.pdf) and turn to page 24. Under "ADJUSTING TOP THREAD TENSION" it tells you that if you're having thread tension issues, change the tension control dial on the top of your machine from auto. It also shows you a diagram with your problem illustrated on the right side of the page. The bobbin tension is set at the factory, so all tension problems can be solved with top tension adjustment. Set it manually and if it loops on top, loosen the tension a little. Test again. Repeat until loops are gone.
Using different colours on top and bobbin and a contrasting fabric (e.g. black top, white bottom, light blue fabric) means you can easily see what's happening. A perfect stitch is when you see exactly the same stitch pattern on both sides of the fabric. On top, the bobbin thread colour appears between stitches as a tiny dot and on the bottom, you see the top thread dot between stitches.
If it's impossible to get the tension right, take it to a technician, because it's a sign that the hook timing needs attention.
Apr 21, 2015 | Singer 8763 Curvy
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
Loose top thread bernina 1008, tension problem but no solutions yet...
Are you sure you are getting the top thread between the tension discs? You should be able to tell the difference when you lower the pressed foot.
Jan 27, 2013 | Bernina 1008
My model 2335 white sewing machine jams, and the the tensions are off. The thread clumps up on the bottom of the material, and the bottom thread is too loose.
here are some suggestions
change the needle
rethread the machine using every thread guide
check to see if the thread has come off the thread take up lever
clean under needle plate & in the bobbin area for lint
adjust the top thread tension one number or letter higher until
the stitches look normal
here's a free manual to download
http://www.singerco.com/uploads/download/1137_white-2335-x.pdf
Sep 11, 2012 | Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
Bernina 180 thread breaking and tension problems
First make sure that you are using a new needle in the proper size. A needle with burrs on it will cause the bird's nest problem. Also, is the thread you are using old? My repair guy told me to keep my filled bobbins in the freezer to maintain their humidity, and that has made a world of difference in my stitching. Finally, how long has it been since you had the machine cleaned and serviced, and was it by an authorized Bernina repair shop? Bernina machines have special screws that only Bernina authorized repair people have - I discovered that when I took my machine in to someone who was not authorized only to have the timing go off in a matter of weeks. The authorized repair guy found clumps of thread that had been air blasted into the inner works of the machine and those clumps were getting caught up in the new stitching and causing the same problems you described. Good luck!
Feb 06, 2009 | Bernina Artista 180
Thread keeps wrapping around bobbin
frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
good luck and happy stitching.
Jan 17, 2009 | Husqvarna Viking 1
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Open Questions:
Sewing Machines Logo
82 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
