Question about Sport & Outdoor - Others
Machine will stop adjusting resistance. On start up the machine will usually work. I can go through the calibration procedure and it will calibrate and work normally for 4 or 5 resistance adjustments. It will then stop adjusting. It acts like there is a cable pulled and refuses to adjust, even though I am not getting the warning telling me to "Release cable" I have modified the wiring harness so that the wires do not fall off from the stepper motor, so this is not the problem. If I shut the machine down and leave it for several minutes, it will come back and work normal again... for a while. I am wondering if there is a problem with the sensors that are detecting a cable pull? Is there a way to disable those sensors to see if that is the problem
  • Scott Roberts Aug 04, 2010
    Model is Weider Wesy78732
  • Scott Roberts Aug 05, 2010
    This advice is out of the ownwers manual! I have tried this. the unit will not even go into this calibration mode when it stops. I am hoping there is someone out there that can give me more insite on what might be going on.
  • Sport & Outd... Master
  • 12,061 Answers
I would think that your problem has possibly to do with a faulty power supply, component, see to my mind it is a thermal problem as it heats up,it goes faulty? The Voltage changes and it goes out of spec.. When left to cool, it then is OK... Usually, & from my experience this is a thermal problem. To see obtain some Freeze Spray, from radio Shack or similar,and spray components on the main power board, and others too, use it on any large heat sinked components and see if when you do this the fault clears. Then replace that component(s).
Or as you suggest the sensors that feed the inputs maybe with sensors though one has little option but to replace them and see if this clears the problem.
Posted on Aug 05, 2010
    Makes sense! I will try this... Thanks
  • 10,865 Answers
Hello. There are several possibilities. Please get back with the make and model of the machine that you have. J.
Posted on Aug 04, 2010
    Weider 78732 Platinum
  • 17,970 Answers
There is not specific sensor for this component; its possible that your problem isn't the cable adjust, sound like a recalibrate needed there. Check this from owners manual...
To recalibrate the Console (67), first plug in the resistance system (see PLUGGING IN THE RESISTANCE SYSTEM on page 17). Then, press and hold the NEXT button and the MOTORIZED WEIGHT ADJUSTMENT + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, then press the MOTORIZED WEIGHT ADJUSTMENT +
button; this will start the recalibration process. This may take a few minutes as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120-
volt outlet.
The Console (67) will be recalibrated. Use the resistance system as described in the CONSOLE OPERATION section, starting on page 17.
Hope this helps to solve it.
Try to program and it comes error L5
PAGE 63-64 in link Describe "LS" error.
7
Belts stop turning and "err
LS" or "err OS" is displayed
Calibration
Re-calibrate machine. (See Calibration Procedures, Pg 26)
SPEED
SENSOR
1. Cycle power off and on
2. Put the machine in calibration mode (see Calibration
procedures, Pg 26) but do not start the calibration routine.
3. Remove right rear base plastic cover to allow access to
LED board. Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board. LED may
be lit or unlit.
5. Manually advance the treadle with your foot, and check
if LED D is blinking.
6. If LED D is not blinking, then the speed sensor is not sup
plying a signal. Check that the speed sensor is connected
securely to P1 on the motor controller. If sensor is con
nected and LED D still does not flash replace sensor.
I/O cables
If LED D is flashing when the belts are turning but err LS
or OS persists, check for signs of visible damage to any of
the three I/O calbes and connections. If no visible damage
check continuity using a multi-meter. If a multi-meter is
not available replace all three cables.
Electronics
If all I/O cables are functioning properly, LED D indicates
speed sensor is functioning, and err LS or OS persists
problem is in either the upper electronics board or the
motor controller board. With machine on check LED A
on the controller board. If it is dimly lit replace upper
electronics (000-4430). If it is not lit at all replace motor
controller.
http://download.nautilus.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
Jun 04, 2014 | Bowflex Treadclimber TC5300
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
I have a MC2100-12A motor controller in this treadmill. The LED blinks quickly like communication is ok but it doesn't control right.The speed sensor also looks ok. When 1mph is selected it runs at 2.7mph...
The speed sensor on these machines have nothing to do with controlling the speed. The machine will run without it. The sensor is obviously working, since you are getting a speed reading.
The calibration is a mechanical adjustment found on the motor controller, the instructions are found under the lid as well as the meaning of the LEDs flashes on the tech sheet..
Follow the calibration procedure. If the operation is still erratic, I would suspect a defective controller.
Calibration: Press stop and speed up. Install the safety key/magnet. release the buttons. Press stop 1 time. one window displays speed, the other the calibration number. Both should be "0".
Press speed up, the treadmill should begin to move around 25-30. increase to 85, the machine should be a max speed. adjust the pot on the motor board to max speed. Some machines are 10mph, others 12mph. The tech sheet will tell you the max speed. When adjusted, press speed down. the machine will stop. Now press incline up. That will calibrate the incline. When completed, remove the safety key.
If operation is still erratic, change the motor controller.. It could be the console, but the cost of replacement makes the repair in most cases uneconomical..
Dec 15, 2010 | Exercise & Fitness
I want have shematic diagram multimetr Mastech mod. MS8222H. I want calibrate my multimetr. Please help me .
To calibrate DMM you need precision AC/DC Voltage, Current and Resistance source (read: expensive calibrator) and standard Capacitors and Inductors or LCR meter and that is just a start. To adjust it you will probably have to guess what pots are for what function because these cheep meters have no adjustment procedure. Your call.
Sep 05, 2010 | Actron Digital Multimeter Tester
Error L5 came up. My friend fell off if and of course the machine stopped because of the emergency cable. But now it won't run the belt.
Belts stop turning and “err LS” Speed sensor.
1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor.
Jul 18, 2010 | Bowflex Treadclimber
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate it?
From main menu: go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop/exit key to complete the prcess.
Jul 16, 2009 | Porter Cable Measuring Tools & Sensors
The machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Mar 18, 2009 | Bowflex Treadclimber
"No Disc"
Here are a couple solutions:
How To Recalibrate DVD Player
Summary:
For those that are having the skiping up and unreadable disk problems try the following calabration. I did it last night and now my DVD's are much clearer and I'm hoping the skiping problem is gone.
For those that have the lip sync problem Sony should cover this for no charge, you just need to push them a little. This is a firmware update, have a look at the other posts at this web site to find the firmware revision that you need.
HOW TO PERFORM THE CALIBRATION
Make sure that the DVD player is turned OFF and in the stand-by mode with the little red LED glowing above the on/off button.
To enter the service mode/test mode, press Title, Clear, and Power on the remote.
This will produce the following menu:
Test Mode Menu
0. Syscon Diagnosis
1. Drive Auto Adjustment
2. Drive Manual Operation
3. Mecha Aging
4. Emergency History
5. Version Information
6. Video Level Adjustment
Exit: POWER Key
What each item does;
Syscon Diagnosis = Leave this for service technicians.
Drive Auto Adjustment = Automatically calibrates DVDs and CDs.
Drive Manual Operation = Manually calibrates DVDs and CDs with prompts for permission to skip, execute and/or proceed after each adjustment is made or skipped. Offers a fascinating look at all of the many adjustments made, but this method is time consuming.
Mecha Aging = Allows auto repeat mode for testing purposes.
Emergency History = Shows the number of hours on your machine.
Version Information = Shows firmware version.
Video Level Adjustment = Test pattern.
Press #1 (Drive Auto Adjustment) on the remote and the following menu will appear:
0. All
1. DVD-SL
2. CD
3. DVD-DL
4. SACD
Exit: RETURN
Press #1 (DVD-SL) on the remote and insert a Single Layer DVD when the drawer opens.
Even though you may be interested in calibrating only a dual-layer DVD, do not skip the single-layer calibration procedure. For some reason, the player prefers to first calibrate a single-layer DVD before proceeding to a dual-layer disc. Error messages may result if the single-layer calibration procedure is not performed first.
Press the enter key and the machine will begin to calibrate all of the playback features. When calibration is completed, follow the onscreen instructions to return to the above menu.
When the Drive Auto Adjustment menu returns, press #3 (DVD-DL) on the remote and insert a Dual Layer DVD when the drawer opens. Follow the instructions as noted above.
When calibration is completed, follow the onscreen instructions to exit from the Test Mode Menu. Now you can turn the player back on and try your dual layer discs to see if the layer change has improved.
If you have any concerns about trying this service mode calibration, leave it for an authorized service facility
Other solutions:
1. To reach this test menu on a DAV-S300, press and hold the "STOP" and "Muting" button on your DVD Player (not remote) and turn the volume nob clockwise about 180 degrees. You will see a flicker. A blue test screen will appear, allowing you to calibrate your DVD. Please note that if you have no technical experience, messing around in this menu can cause serious damage to your DVD. The calibration option will be under: option 1, Disc Drive Auto Adjustment (or words to that effect). Be sure to calibrate a single-layer disc first, then dual layer -- you need to calibrate both types. Good luck.
In order for the STOP + MUTE + VOLUME sequence to work, your player must be ON, but have no disc present. You need to empty the tray, power off the S300 and power it back on. Wait until the INSERT DISC/NO DISC prompt appears. Then try the SMV sequence. And you must use the buttons on the unit, NOT on the remote, to enter the service menu. Once in the menu, use your remote to select the auto calibration menu and go from there.
2. This will fix the C 13:00 problem on any Sony DVD player.
With the machine turned off on standby, press the following 3 buttons
on the handset, in order: TITLE CLEAR POWER. The Diagnostic Start menu will come up on the TV. Select the appropriate button number for "auto adjust". The
machine basically does it all. It asks you to select either a single
layer or double layer disc (whatever your offending disc is.) Ejects
the tray, asks you to put your disc in and then calibrates it. (It's
over in about half a second... painless) Just follow the prompts on the screen
Aug 17, 2007 | Sony DAV-S300 System
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
