Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Installed new battery, nothing happens when you try to start, could it be one of the safety switches ?
  • 103 Answers
The battery posts are most likely not getting enough coverage on the battery terminals. clean the terminals and the wires very well with a wire brush. other than that make sure you are sitting on the tractor the key is on and make sure that both the drive and the blade are set to off.
Posted on Aug 04, 2010
2013 Accord not starting Already replaced the starter and installed a new battery but nothing happened. When I turn the key I heard a "click" and nothing else. Lights in the dashboard remain all lit
Move the car about foot and retry. If it works, your flywheel might be bad. If that doesn't work, you may have a starter relay fuse, neutral safety switch, or brake switch going bad.
Jan 19, 2018 | Cars & Trucks
Car will not turn over. All lights, bells, and whistles work but turn the key to start and nothing happens. It has a new starter, battery, alternator, and ignition switch. I replaced the 20 amp fuel/start...
Neutral safety switch if automatic, Or Clutch safety switch if manual. Hope this works for you. If its Automatic place in neutral and try and star it.
Feb 19, 2018 | Cars & Trucks
2003 Silverado will not start; the satrter and battery are ok but nothing happens when key is turned
Have you tried starting it in neutral? Is it making any sound at all? Is it an automatic or standard? If it's a standard it may be your clutch safety switch, if it's an auto it may be a faulty neutral safety switch.
Dec 17, 2013 | 2003 Chevrolet Silverado 1500
Craftsman LT 1000 Model: 917.272650 I put a new battery in over the weekend and was running perfect for most of the day Saturday. I got off it to empty the bagger, and as normal, the engine stopped. I...
check to make sure that mower deck drive is not engaged. there is a switch that the lever presses on it must be free. also check for seat switch cables loose or disconnected. Also make sure it is in neutral and not reverse as it may also kill the circuit for safety. Depends on you system for mow backwards. with key on you can short the two large terminals on solenoid to see if starter works. if so you must check all safety switches . try setting park brake before trying to start too.
May 17, 2013 | Garden
I have a 04 kia optima that stalls and when you try to start it nothing happens no dash lights nothing for about 2 to 5 mins.
try starting in nuetral when this happens the most probable cause is nuetral safety switch/multi-function switch on trans. common cause
Aug 28, 2012 | 2002 Kia Optima
Car won't start
A mechanic would check for voltage at the starter, the neutral safety switch, and the key switch. Also check the ground connections.
Jul 30, 2012 | 1991 Plymouth Acclaim
I turn the key nothing happens? I have new battery, I put in a new starter, all the lights and bells work. The starter has been tested it'"s new. I changed ignition relayy switch still nothing It...
I have a 93 pathfinder SE 4X4 automatic transmission that had full power, new starter and battery. Sometimes it will start and sometimes not. By passed starter relay by adding push button start and it started 6-8 times then nothing. I finally figured out that it was the neutral safety or inhibitor switch on the 4 wheel drive shifter. Just an idea..good luck
Jun 20, 2011 | 1993 Nissan Pathfinder
Wont start,battery is good,turn ignition switch and nothing happens not even any clicking.i replaced the starter from another good running car and installed an newfloor console,could the problem be the...
You could try replacing the two fusible links down by the starter. They look like two black pieces of rubber on the wires. Just cut them out and splice the wires back together. If that's your problem it should start. If you unplug the neutral safety switch from the tranny the car should start if that is the problem. Hope this helps.
Jun 04, 2009 | 1989 Chevrolet Camaro
1996 ford f-150 truck
try checking you Park/Neutral safety switch. if that's faulty it will do exactly what you are saying and while you're at it test the ignition switch but i'm leaning towards the safety switch
Aug 18, 2008 | 1996 Ford Explorer
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
