Question about Dryers
Seimens wt 3301 How to install a belt
Hi have old but great dryer wt 3302
i need to install a belt the original broke to 2 parts
i open the back side and the top
cant see who to install new one
thanks ran
Hi
it very simpel
opening back and top of the dryer
opening back bearing - by 4 small scrows
push out the shapt holder
install the new belt
close every thing
start to work
Posted on Apr 27, 2008
I just had the belt replaced on my "Maytag" Gas Clothes Dryer Model #DG608. The repair man installed the new belt with the smooth side toward the drum as per one set of instructions derived from...
Herman usualy the groove side goes toward the drum which means it rides on the pulley from the motor disconnect and lean backwards to get a visual
Apr 05, 2011 | Dryers
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Drum does not rotate!
Good day,
Yes, it sounds like a broken belt.
To replace it, remove the lint filter on top, and remove the 2 screws under it.
With a narrow screw driver, pop one side of the li, then the other.
Now rotate the lid up but do not go above vertical.
There are 2 screws holding the front panel on at the top.
Remove the 2 screws, and then unplug the door switch wires. and the support clip for them.
With the front tilted an inch or 2 lift the front panel up and off.
Here is an excellent tutorial.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
The belt can be purchased at any appliance parts house.
IMPORTANT> On some of the newer models the belt tensioner was nothing more than a piece of spring metal.
It will be found on the bottom right side of the dryer floor.
If that's the style, it's a known deficient part, and must be replaced with the old version with has a wheel.
A good counterman will know all about it. Take the old one with you.
Dec 14, 2009 | Whirlpool LGR5636L Gas Dryer
I have a kenmore series 80 dryer model 110-70812990 that i heard a bang then the drum stopped turning and i smelled burning rubber. I'm guessing that the drive belt broke. How easy would that be to repair...
Remove back of drier after disconnecting the power cord. Find old belt laying on floor under machine. Obtain new belt and place around drum and motor pulley. done
Dec 26, 2008 | Dryers
Hi there I am trying to replace a belt on my old dryer how hard is it
If you have a NVL333EY which you posted under, I'd rate the repair a 4 on a scale of 1 - 10 in difficulty. That Hotpoint model is actually manufactured by Frigidaire / Electrolux and sold through GE as a Hotpoint. (Hey, it's a global economy, right?)
Disconnect power to the dryer. Use a putty knife to push in the seem of the front panel with the dryer top to release the dryer top, allowing it to swing back. You may be able to use a phillips to remove the screws holding the front panel, but a #2 square drive works much better. Slip new
134503600 belt around drum from front. Put front panel back on. Remove 4 screws (again the #2 square drive works best) holding the back access panel at lower left back side to allow you to finish belt installation. Belt grooves touch the drum. The worst part is keeping the spring from falling off when you put the belt tensioning wheel on. After you have the belt installed, give the drum a turn by hand to make sure everything is OK before you close up the top and reconnect power.
Dec 07, 2008 | Hotpoint NVL333EY Electric Dryer
Belt
The top must be lifted and the front must come off so you can slide the new belt on. When that is done in the back you will see a panel to be removed. Slide the belt back and install it around the pulley on the motor. When you are done put it back together and wala. I hope this helped you out.
Nov 24, 2008 | Whirlpool LER4634J Electric Dryer
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Need way to open the iron 3302
Usually start at the cord end to locate internal screws to get top off then down to the next layer
Aug 01, 2007 | Toastmaster 3302 Iron
Dryers Logo
61 people viewed this question
Top Dryers Experts
