Question about Whirlpool Duet GHW9150P Front Load Washer
We bought the Duet washer and dryer less than seven years ago, we have had at least two doors replaced on the washer. We now find the washer is no longer working, the parts needed to repair this appliance are $800, we are Seniors, this washer looks like new.......this appliance is JUNK, what will Whirlpool do to compensate us for this???? Whirlpool was highly recommended.....we paid a lot of money for this set and feel Whirlpool should do something......we need to replace this asap....it is very frustrating not to be able to speak with anyone regarding this. Patricia and Wayne Titus,30 Corbett Road, Morrisdale, New Brunswick 506-757-2975 I would like someone to call us about this, it is 12:10, mid day.
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
How much is this Model worth? 6 years old?
Worth Not much as life expectancy on most new appliance is 4 years or less ,it called plan obsolescence or made to fail as economy is based on consumerism not quality
Aug 20, 2014 | Whirlpool Duet Front Loading Dryer Rack...
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load dryer MODEL GEW9200LW1. Pressed end cycle button to see if it was locked. It isn't locked. Pressed door button, it clicks. Pressed more time, less time, more time,less time. It...
It appears your fuse has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Jun 12, 2010 | Whirlpool LAB2700ML Pedestal Drawer for...
The door will not unlock
Hello,For the washer, hold the End of Cycle button for 5 seconds. For the dryer, press "More time", "Less time", "More time", "Less time" buttons in that sequence within 5 seconds.
Thanks
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Sport wfw8300sw02, is a piece of junk. Don't buy it. Two weeks ago service came out to replace the rubber boot because the washer was leaking. Than they replaced the front panel. Last week...
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Dec 03, 2009 | Whirlpool WFW8300SW
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer door will not open
only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
Nov 13, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washer vibrates on spin cycle and is falling apart,
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You say, your door is cracked.soap dispenser is cracked and falling apart?
How old is the washer????????????
Waiting for your response!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Aug 27, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Whirpool duet front load washer door trouble
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
43 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
