Question about Card Scanning Solutions ScanShell 800N Pass-Through Scanner
Scanshell 800n scanner feeding not working. it will slowly scan 1 side but will not scan the other then it will stop and not scan at all
Benimur
  • 6966 Answers
SOURCE: Need help starting up a ScanShell!
You need to be running a particular program for the unit to be activated. There are several and so we wouldn't know which one is installed. You can try looking at Start/All Programs/anything that says "***Scan***" such as ScanShell 800N, Scan2Contacts, Scan2Web for Business cards, IdScan for Business Cards, Scanshell.net for Business Cards and a lot more.
Additionally, instructions for use depends on what the scanning is intended to be used for: email, web, database, ACT, CRM or plain card. Perhaps this site can help you by clicking on the particular operation you are interested in.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 04, 2008
SOURCE: scanshell 2000nr
I bought another scanner - too much trouble trying to sort this one.
Posted on Jul 02, 2008
SOURCE: scanner buzees and moves slowly and scan's all photos as one
I fixed the problem by updating a driver I found in the Epson site. It woeks great once again.
Posted on Apr 01, 2009
  • 32 Answers
SOURCE: Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Posted on Apr 07, 2009
  • 332 Answers
SOURCE: My scanshell 800 DXN has started scanning lines
I am very familar with the scanshell scanner you have I have repaired several of them in the past.
There really isnt anything that wrong with your scanner it just needs to be calibrated. When you purchased it there was a calibration sheet included in the box that you need to use I hope you still have it. If not go here to purchase some new sheets http://www.scanshell-store.com/accessories.htm They used to be free but when I looked at there web page they are not listed any longer. Also here is a link to a 800 manual which describes how to run the calibration process http://www.id-reader.com/ftp/applications/manual/scanshell_manual.pdf This will correct your problem and your scanner will be as good as new again.
I hope this helps you out and if it does please leave me some feedback.
Posted on Apr 02, 2011
How to disable the pop up of saying "The paper was not detected. Continue anyway?"
U cant turn off error notifications on these scanners. It could be the firmware version needs to be updated. also the reset instructions are on the support page under know issues. Try if u can using it on another system to see if its a compatiblity issue on this system. Does it continue to scan after error code>
Ill follow this to see. If still issues reply with more info..ie system OS other devices connected like printers or other usb devices.
Good Luck
Chadman
Dec 23, 2013 | Card Scanning Solutions ScanShell 800N...
My scanshell 800 DXN has started scanning lines over the card image almost like there's something on the scanner eye. Is there a way to clean it?
Mar 29, 2011 | Card Scanning Solutions ScanShell 800DXN
9891583063 - Details for this no name full add and alternet no,
Sir ji lagta hai app galat jagah pe agaye ho.yaha gadgets ke solutions milte hai.
Jan 04, 2011 | Card Scanning Solutions ScanShell 800N...
Redish tint on ID cards
There really isnt anything that wrong with your scanner it just needs to be calibrated. When you purchased it there was a calibration sheet included in the box that you need to use I hope you still have it. If not go here to purchase some new sheets http://www.scanshell-store.com/accessories.htm Also here is a link to a 800 manual which describes how to run the calibration process http://www.id-reader.com/ftp/applications/manual/scanshell_manual.pdf This will correct your problem and your scanner will be as good as new again.
Nov 30, 2010 | Card Scanning Solutions ScanShell 800N...
Which scanner works best with windows 7
I have repaired many scanshell scanners in the past so maybe I can help you.
I believe all of their current products today work under Windows 7. You will have to decide what product you need and how you will be using it. On this link I am sending you it does have a support page at the top to ask any questions you like and for some advice directly from them. Its a good product and you wont go wrong with them. Here is there link http://www.scanshell-store.com
Sep 14, 2010 | Card Scanning Solutions ScanShell 800N...
Purchased scanshell 4 years ago, have it installed but recently upgraded our server and had to re-install but dont have the original product key. please help
I have repaired scanshells in the past so I am very familiar with them.
I believe you only need the product key to use the software that was provided with the scanshell. You can scan with that scanner through MS Paint or Adobe Photoshop or Paintshop Pro it will accept any of those programs. If you really need to scan through the software that came with your unit you can contact scanshell here and ask them for a new product key. They are nice people to work with and Im sure they will help you out here is there link http://www.card-scanner.com/index.html Go to support at the top of the page and tell them what you need.
I hope this helps you out and if it did please leave me some feedback.
Aug 27, 2010 | Card Scanning Solutions ScanShell 800N...
Do you carry motor for scanshell 800 dxn scanner and if so what is the cost?
I have scan shell 800. From last few days it's scanning nothing but black dots and line. Did recalibrate couple of times, unplugged and plugged back in to reset it without success. Any suggestions ????
Jul 23, 2009 | Card Scanning Solutions ScanShell 800DXN
Scanshell 2000nr
Jul 01, 2008 | Card Scanning Solutions ScanShell 800N...
Apr 04, 2008 | Office Equipment & Supplies
Card Scanning Solutions ScanShell 800N Pass-Through Scanner Logo
245 people viewed this question
Top Card Scanning Solutions Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Card Scanning Solutions Office Equipment and Supply Expert? Answer questions, earn points and help others
