Question about Dishwashers
Bleeping constantly, does fill but not wash and turn, 3 hour delay comes on
    Problem Solver:
  • 13 Answers
One of a few problems here, common one is the element has burnt out try replacing however the programmer might be burnt out.
Posted on Aug 04, 2010
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
Frigidaire front load washer FTF2140 upon start it began filling and then turn off, did this everytime. Unplugged it and the same thing happened. Now the lights stopped coming on and it does not work.
Good Morning Heather,
I understand that your Frigidaire washer, model# FTF2140, begins to fill and then turns off. You unplugged it, trying to reset it, and now the lights are not coming on and your washer is not working. Since you have already reset your washer, by unplugging it, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your washer not working is. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer?
In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
Feb 20, 2014 | GE GTWN3000MWS Washer
Retains water (after a delay) in the drum after a wash cycle. Immediately after the wash cycle there is no water in the drum, however after several hours the drum has water in it?
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill! To find out which it is in the case of hot and cold fill turn the cold tap/faucet off overnight and see if water has come in or not. that will tell you. Also to check that it is just a physical problem and not a control board problem switch the machine off at the supply. If it still does it (from whichever supply) it is that valve which is not closing correctly ;-0
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 16, 2011 | AEG Lavamat 12710 Front Load Washer /...
I set the machine to wash,it began to fill and several hours layer had filled to only 1/2 capacity with the timer showing the time remaining until the total wash time was finished. I turned it off and on...
It is possible that the inlet valve is clogged and so the water flow is restricted. You must obtain a good flow into the washer tank after the program is started.
So remove the inlet valve and clean the filter, clean the valve and set to test once again,
Since the program is delayed the program timer detects this as an error.
Feb 15, 2011 | Samsung Washing Machines
Daewoo DWD G1243S washing machine not filling properly. 'ie' coming up on display & bleeping. What can i do to solve it?
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
Dec 27, 2010 | Daewoo Washing Machines
Dishwasher runs about 3 hours
First check the inlet water flow into the machine. There is a strainer attached to this. If it is clogged water filling into the machine will be delayed!
Also check whether using the same wash program as you were doing earlier. There can not be any other fault aprt from this. i presume the wash quality is good.
Heance clean all the water inlet and outlet for free flow.
Jul 08, 2010 | Siemens 24 in. SE25A091 Hi-Line...
I have the code for my 2002 land rover discovery i just dont know how to put it in, any ideas thanks
To enter the EKA:
Close all the doors.
Turn the key in the driver door lock to the unlock position and hold there for at least 5 seconds until the alarm sounds once. Then return to centre - always ensure you return to centre and do not delay more than 10 seconds between turns, or hold in the position for more than 5 seconds or you will reset to the start. Turn to full extent of travel.
1st Digit turn to unlock the number of times specified.
2nd Digit turn to lock the number of times specified.
3rd Digit turn to unlock the number of times specified.
4th Digit turn to lock the number of times specified.
Finally turn to unlock once more. If it is correct a double bleep will sound (single bleep is incorrect code)
You now have a 5 minute delay - don't open any doors. The anti-theft indicator will continue flashing once every 2 seconds for the five minute period. When this goes out, open the door and start within 30secs.
After 3 failed attempts, the security system invokes a delay period of 10 mins during which the system will not accept any further attempts to enter a code.
Oct 19, 2009 | 2002 Land Rover Discovery Series II
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
