Question about Microsoft Office Outlook 2003 for PC
SOURCE CODE OF FTP SERVER IN VISUAL BASIC
I want to sourcecode of ftp server application in vb6.0 which includes functionality:
authentication of user
upload file in that user domain
download file
rename file
delete file
save file
  • 1 more comment
  • anita62 Jan 03, 2009
    Hi This is Anita,
    Me too want to upload and download the FTP File through visual basic code. need some urgent help plz help me
  • ravindra2411 Mar 11, 2009
    I have same problem but i want to connect to FTPS also
  • Anonymous Mar 13, 2009
  • 4 Answers
Hi Ankita,
I suggest to do a quick search on planetsourcecode.com and you will get many source codes in VB, just change the drop down box to VB before you hit the search button
Cheers,
Victor.
Posted on Jun 20, 2008
Send me an email expressing your exact problem i have some experience which i might be able to help you
babrakzai1@yahoo.com
Posted on Nov 01, 2008
How to Share Files With Cerberus Ftp Server?
FTP and SSH SFTP are application protocols designed to allow
individuals and businesses to easily transfer files between
computers. The two protocols are commonly used to transfer
data reliably and efficiently, whether it is uploading important
files to your home backup system or securely sharing company
files between two remote offices.
Setting up an FTP server will allow you to receive and share files
with virtually anyone, anywhere in the world. This tutorial will
walk you through the basic steps of downloading, installing, and
configuring Cerberus FTP Server . In addition to standard FTP and
HTTP, Cerberus can also secure your connections with encrypted
SFTP , FTPS, or HTTPS .
You can also use this link to download it How to Setup File Server with Cerberus FTP Server
Oct 19, 2016 | Computers & Internet
Tip
Bullet Proof FTP Server Tutorial
This is for the BulletProof FTP Server 2.10. However, It should work fine on most following versions as well.
I'm assuming you have it installed and cracked.
Basics 1. Start the program. 2. Click on Setup > Main > General from the pull-down menu. 3. Enter your server name into the 'Server Name' box. Under Connection set the “Max number of users" to any number. This is the limit as to how many users can be on your sever at any time. 4. Click on the 'options' tab of that same panel (on the side) 5. Look at the bottom, under IP Options. Put a check in the box “Refuse Multiple Connections from the same IP”. This will prevent one person from blocking your FTP to others. 6. Also put a check in the 'Blocked Banned IP (instead of notifying client). VERY IMPORTANT! If somebody decides to 'Hammer' (attempt to login numerous times VERY quickly) your server/computer may CRASH if you don't enable this. 7. Click on the 'advanced' tab 8. At the bottom again look at the 'hammering area' 9. Enable 'anti-hammer' and 'do not reply to people hammering' Set it for the following: Block IP 120 min if 5 connections in 60 sec. You can set this at whatever you want to but that is pretty much a standard Click 'OK'
Adding Users 11. Setup > User accounts form pull-down. 12. Right click in the empty 'User Accounts' area on the right: choose 'Add' 13. Enter account name. (ie: logon name) 14. In the 'Access rights' box right click: choose ‘Add’. 15. Browse until you find the directory (folder) you want to share. In the right column you will see a bunch of checkboxes. Put a check in the following ones: Read, Write, Append, Make, List, and +Subdirs. Press 'select'. 16. Enter a password for your new FTP account. 17. Click on 'Miscellaneous' in the left column. Make sure 'Enable Account' is selected. Enable 'Max Number of Users' set it at a number other than zero. 1 for a personal account and more that one for a group account. Enable 'Max. no. of connects per IP' set it at 1
18. Under 'Files' enable 'show relative path' this is a security issue. A FTP client will now not be able to see the ENTIRE path of the FTP. It will only see the path from the main directory. Hide hidden flies as well. Put a tick in both of these.
Advanced: You don't need to do any of this stuff, but It will help tweak your server and help you maintain order on it. All of the following will be broken down into small little areas that will tell you how to do one thing at a time.
Changing the Port The default port is always 21, but you can change this. Many ISPs will routinely do a scan of its own users to find a ftp server, also when people scan for pubs they may scan your IP, thus finding your ftp server. If you do decide to change it many suggest that you make the port over 10,000. 1. Setup > Main > General 2. In the 'Connection' Area is a setting labeled 'Listen on Port Number:' 3. Make it any number you want. That will be your port number. 4. Click 'OK'
Making an 'Upload Only' or 'Download Only' ftp server. This is for the entire SERVER, not just a user. 1. Setup > Main > Advanced 2. In the advanced window you will have the following options: uploads and downloads, downloads only, and uploads only. By default upload and download will be checked. Change it to whatever you want. 3. Click 'OK’
While you are running your server, usually you will end up spending more time at your computer than you normally do. Don't be afraid to ban IP's. Remember, on your FTP you do as you want.
When you are online you must also select the open server button next to the on-line button which is the on-line Button
You also have to use the actual Numbered ip Address ie: 66.250.216.67
Or even Better yet, get a no-ip.com address
on Feb 08, 2010 | Computers & Internet
How to set up a FTP server in Windows 7
You can use MS products (FTP Service and IIS Management Console) or a third party software (FileZilla.)
To use MS, you have to enable FTP under "Add Features" in Programs and IIS service.
Then you have to configure IIS:
  1. Run Administrative Tools -> Internet Information Services (IIS) Manager
  2. Expand the local machine
  3. Right-click "Sites" and add "FTP Site"
  4. Call it "Default FTP Site" and create the path like "C:\inetpub\ftproot"
  5. click "Next"
  6. Enable Start FTP site automatically, select Allow SSL
  7. click "Next"
  8. Enable Anonymous Authentication
  9. click "Finish"
Oct 15, 2015 | Computers & Internet
Server erro 530 , error on page cause it to work incorrectly
Error Code 530 b> This error code means that FTP authentication was not successful. The combination of the username and password you've typed was incorrect, thus you were denied access to the FTP site. It could also mean a misconfiguration in IIS: You've allowed only anonymous access for FTP, but denied anonymous access for all IIS services. Verify that the username and password you used is correct or check if anonymous access is allowed by leaving the username and password options blank.
Jan 12, 2013 | Computers & Internet
Free download because.i need in my school.
MICROSOFT VISUAL BASIC 6.0 PORTABLE Microsoft Visual Basic 6.0 has many advantages compared to other software or programming language, among the advantages of visual basic are as follows: a. Learning curve and development that is shorter than that of other programming languages ??like C / C + +, Delphi or PowerBuilder even though.b. Eliminate the complexity of Windows API function calls, because many functions - these functions have been "embedded" into the visual basic syntax.c. Suitable for developing applications / programs that are "Rapid Application Development).d. It is used to create a program or business applications.e. Used by nearly microsoft office as a macro language and will soon be followed by others.
f. Can create an ActiveX Control
g. Can use the OCX or component provided by third parties (Third Party) as the developer tools.
h. Provides a wizard that is very useful to shorten or simplify application development.
i. Approaching Object Oriented Programming.
j. Can be integrated with the Internet, be it on the client side and server side.
k. Can create an ActiveX Automation Server.
click on the link and download http://www.mediafire.com/?37hlpq6h1e5xf4s
password to unlock the file is -
freesoftwarepc.biz
Aug 07, 2011 | Microsoft Visual Basic 6.0 for PC
How to configure FTP server in vista home basic
I don't believe that Home Basic has an FTP server component built-in. Try a free alternative, such as NcFTP server.
Feb 11, 2010 | Microsoft Windows XP Professional x64...
Hello
SOCKS is an Internet protocol that facilitates the routing of network packets between client-server applications via a proxy server. SOCKS performs at Layer 5 of the OSI model - the Session Layer (an intermediate layer between the presentation layer and the transport layer).
Clients behind a firewall may connect to a SOCKS proxy server in order to access external services through the firewall. Such a proxy server controls the eligibility of the client to access the external server and, if the client has eligibility, passes the request on to the server. SOCKS can also be used in the opposite way, allowing the clients outside the firewall ("exterior clients") to connect to servers inside the firewall (internal servers).
SOCKS software
* Kernel SOCKS Bouncer ksb26 (Kernel Socks Bouncer) is a Linux Kernel 2.6.x Loadable Kernel Module that redirects TCP connection (to user-defined target hosts) through socks 4/5 chains.
* SS5 Socks Server is an open-source SOCKS4/SOCKS5 server.
* Dante is an open-source SOCKS4/SOCKS5 implementation with commercial support developed by Inferno Nettverk A/S.
* OpenSSH allows dynamic creation of tunnels, specified via a subset of the SOCKS protocol, supporting the CONNECT command.
* WinSocks is a light-weight SOCKS4/SOCKS5 server developed by Proxy Labs.
* SOcat Multipurpose relay (SOcket CAT): includes socks4, and socks4a functionality (Linux / Mac)
* FreeCap Socksifyer for Windows, any App can run its network traffic transparently via a SOCKS or HTTP proxy.
* Simple Socks Server for Perl - SSS is a Simple SOCKS Server written in perl that implements the SOCKS v5 protocol.
* Sun Java System Web Proxy Server is a caching proxy server running on Solaris, Linux and Windows servers that supports HTtp://S, NSAPI I/O filters, dynamic reconfiguration, SOCKSv5 and reverse proxy.
* BarracudaDrive Web Server - commercial SOCKS HTTP HTTPS tunnel/server, available for Windows, embedded Linux and Mac OS X (PowerPC)
* DeleGate is a multi-purpose application level gateway and proxy server which runs on multiple platforms. Beside SOCKS it also supports HTTP(S), FTP, NNTP, SMTP, POP, IMAP, LDAP, Telnet, DNS and many more.
Jan 05, 2009 | Computers & Internet
How to configure FTP server in windows xp prof ?
Setting up an FTP site Using Windows XP Professional Windows XP professional (as well as Windows 2000) includes Microsoft's IIS (Internet Information Server) which can be used to create an FTP site on your computer. It's a fair bit less complicated and less flexible than using some third-party FTP server software packages, so we will give you guides for setting up both. If you are using XP Home you will need to use third-party software. There is no way to publish an FTP site with the Home Edition of XP.
The first step is to check that IIS (Internet Information Services, Microsoft's web-server application) is configured properly.
Go to start\'control panel'\'add/remove programs'\ choose the 'add/remove windows components' button from the bar on the left. Highlight the item 'Internet information services (IIS)' If it is unchecked, check it, then click 'details.'
The components you will need are: 'common files,' 'file transfer protocol (FTP) service' and 'internet information services snap-in.' Uncheck any others then click next. IIS will configure itself, and you may be prompted for the XP CD.
Mar 21, 2008 | Microsoft Windows XP Professional x64...
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
Microsoft Office Outlook 2003 for PC Logo
1,382 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
