Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
My refrigerator is not very cold yet my freezer is staying cold. The compressor is running and cycling on and off.
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
The freezer doesn't freeze that good but the refridgerator does work.
It is possible that the defrost cycle is not working. Look for signs of ice built up in the freezer compartment. The excess ice prohibits the air circulation.
26128165-5xkmzur1kbcrfneaoxy43scu-3-0.jpg If defrost cycle appears working and compressor runs continuously it is probable that the Freon is low or compressor is failing.
the usual tell is the refrigerator gets colder than usual and the freezer does not get as cold. The situation is that the compressor runs until the freezer temperature is satisfied. If the compressor can not achieve the cold temperature of the freezer it will run continuously.
When the unit runs continuously the bi-pass of air is increased bringing more cold air into the refrigerator portion of the unit.
Mar 13, 2016 | Cars & Trucks
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
I have a Whirlpool refrigerator Model WBM 35 ix that is about 5yr old . The problem i am having is with the freezer. (the frige area stays cold) Some times the freezer will work and freeze food but i...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Apr 23, 2011 | Kitchen Ranges
When refigerator compressor starts , it runs for a few seconds and then quits. freezer and refrigerator compartments not getting cold.The compressor will click on and off at intervals but won't stay...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Jan 05, 2011 | GE Profile Stainless Bottom-Freezer...
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Compressor running non-stop
Temperature setting/changes takes more than 2 hours to stabilize.If still running non stop after 24 hours use a digital thermometer to check the internal temp of refrigerator. If not cold enough it will not open the thermometer and turn off the compressor. Meanwhile, a 20 minute defrost cycle is about right.
Sep 23, 2017 | Amana ARB220ZCS Bottom Freezer...
Refrigerator and freezer are not getting or staying cold, lights on in fridge and freezer,motor sounds like it is running.
These are the things to check for:
Frost build up on the back panel in freezer section
Condenser fan not running
compressor short cycling
dirty condenser
Checks these and then let us know which one might be the problem and we will show you what to do next thanks
Mar 28, 2010 | Amana ABB1927DE Bottom Freezer...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Dec 02, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
