Question about Dell PowerEdge 1750 Server
PowerEdge 1750 can not recognize the Local Harddrive
The ARRAY process went through but system still can not see the drive.
Thanks
If you are using a mother board scsi raid on the Power Edge 1750 it should tell you in the start up what version 4D 4Sc extra
here is a link to Dell's down load for the driver
http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R106088&formatcnt=2&libid=0&fileid=136959
Posted on Nov 12, 2008
    Scholar:
  • 47 Answers
If the array creation process was successful but the operating system doesn't see the new drive, it's probably because the RAID hardware drivers aren't loaded. Check the Device Manager and see if there's unrecognized devices, and if so, try installing drivers for whatever particular RAID hardware's installed in your server. Try searching the dell site for PowerEdge 1750 RAID drivers.
Posted on Jun 10, 2008
    Novelist:
    Scholar:
  • 134 Answers
I think you need to provide heaps more info, like what operating system etc.. Have you tried to change the interface to another port eg if IDE, then move the cable to the secondary or if sata test the drive with another cable/port.. Have you tested the drive in another computer? OK, if it's scsi, then does the drive need a termination? Most scsi drives need a dongle or a terminator to allow them to be recognised.
Posted on Apr 26, 2008
WONT RECOGNIZE ADDED DRIVES ADDED 2 ADDITIONAL 146
If they are SCSI drives, you must enter the SCSI configuration software during a powerup and initialize the drives. From there, you can add them to a drive array or create a new array.
Feb 18, 2011 | Dell PowerEdge 1600SC Server
Need to increase the hdd size in a dell poweredge 1600sc with raid 1
You will not be able to increase the hdd size of a raid array, it's size is set. If you need more storage, you can add additional drives ( either in raid or standalone ) and use the new drive(s) for storage, but the original array will remain unchanged. The other option is to back up all of your data, install new drives and create a new array.
Feb 10, 2011 | Dell PowerEdge 1600SC Server
PowerEdge 4200 RAID 5 - 2 out of 4 failed. Getting "Operating System Not found". Option replace 1 drive of the two that failed. Option 2 replace both drives. Option 3 send all 4 drives for...
If two drives have failed out of a RAID 5 array, unfortunately i'm pretty sure that means that the array has degraded beyond its redundancy level.
Advanced data recovery may be able to help with getting your data back, but I wouldn't pin your hopes on it. Once two discs fail, the array becomes degraded, and the data is irrecoverable.
Did you manage to make a backup before the drive(s) died?
Feb 02, 2011 | Dell PowerEdge 4200...
What hard drives can I use as replacements?
Call Dell with your Service Tag.
Lifetime support is included on all Dell servers.
Last time I called them I dialed (800) 945-3355
They can sell you the hardware you need and guarantee it will work with your server. They might even be able to help explain the process of installing the drives.
I recommend that you use Acronis' Imaging software (www.acronis.com) so that you can make an exact copy of your data and apply it to the replacement volumes. If you are using a RAID1 array make sure the new array is completely built before applying your image. Builds can take a long time. I created a RAID1 array with 2-320GB disks and it took 3.5 hours to build the RAID1 array.
I hope this helps.
Please vote for my solution if it helps.
Apr 19, 2010 | Dell PowerEdge 2500 Server
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computers & Internet
Dell PowerEdge 1400SC Can not locate hard drives or partition
The controller (probably a RAID controller) that the drives are connected to is one for which Windows does not have the correct drivers. You need to supply the proper driver and .INF files during the initial load. The process used depends on the version of Windows you are installing.
Feb 19, 2009 | Dell PowerEdge 1400...
Poweredge 1600sc cant see other 4 drives
HI thanks for reply. i must say im new to this raid stuff. i was given the server by my coworker because he could not get the other drive to show in windows. he got fustrated and gave it to me. so i tey at home. ok here is what i have.
Dell poweredge 1600sc. it has two gig ram. I open the case andther it has one primary hdd and four other hdd connected on one ribbon to the board. it had windows server 2003 all ready on it. I was in the set up (ctrl +m) and i saw the drives say ready. i hit the space bar to set array. after i did that it say i had to initlize it before i reboot. now the drives say online. i boot into windows and the drives are still do not show. am i looking in the right place. i know. im stupid. go ahead and laugh.
plus is there a good place to lean this raid stuff. thanks. nezza
Aug 05, 2008 | Dell PowerEdge 1600SC Server
Dell poweredge 830 sever
You must figure out if there is a harddrive controller running the drives. If this is a striped array I suggest calling support. Pulling all drives and it gets through the POST process the board is fine. Do not swap HDD slots unless you suspect a backplane failure. Most modern controllers support drive roaming, but why chance it....(if you have a hotswap bp)
Apr 08, 2008 | Dell PowerEdge 1800 Server
Unit keeps powering down every 15 minutes
check the internal sensors. There were 2 of them that sensed the internal temp of the system. the one in front sometimes would break. Those units also had a smart card that did all the montoring. Its the only isa card in the system. It can cause these weird problems.
Mar 19, 2007 | Procom NetFORCE 1750 (NF-1750) Hard Drive...
Dell PowerEdge 1750 Server Logo
1,551 people viewed this question
Alun Cox
