Question about Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator
Bottom freezer on Samsung french door RFG297AAP is icing up.
SOURCE: I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Posted on Nov 07, 2008
  • 400 Answers
SOURCE: Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Posted on Mar 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
  • 6 Answers
SOURCE: My french door with freezer at bottom ,LG icemaker
Perhaps there is not enough water coming into the tray on each cycle? Are the ice-cubes very thin? If so timer needs to be reset. LG use a 3-switch DIP on a control panel near the main power board. By changing these switches to various combinations of on/off you can change the timing - longer means more water each time (but too much water means overflow into the blocks already made).
There are service manuals that explain what each setting does - but because its near the high-voltage power board, I'd suggest you get a repairman unless you are a good DIY'er
Posted on Jun 10, 2009
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Samsung french door fridge has clicking ice maker, what is wrong
The gear that turns the ice maker is Nylon and is most likely striped
You would be better off replaceing it with a New One, find it on ebay
Apr 28, 2014 | Samsung RF265AA Bottom Freezer French Door...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
Why is my icemaker not working
My Samsung French-door frig had the same problem - try resetting ice maker - red button on the side of the ice maker. If that doesn't work call Samsung service - I had a bad circuit board which needed to be replaced by local Samsung repair service.
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
Aug 30, 2008 | Samsung 25.5 Cu. Ft. Side-by-Side...
Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
701 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
