Question about Sharp AF-S120FX Air Conditioner
My AF-S120FX sharp air conditioner will work for about 15 minutes and then stop and the error/problem code E1 shows up. Do you know what this code means and/or how to correct the problem?
  • 909 Answers
Check the outside fan and condenser . condenser must be really clean and fan must operate. Make sure the fan on the evaporator in the house is working as well. Pressures exceed rated running values if not.
Posted on Aug 04, 2010
  • thinklittle Aug 30, 2010
    That is not the problem. The problem is that there is an E1 error.. and it has something to do with cleaning the filter and then resetting the air conditioner. Any more info on this would be great.. thanks :)
What does the code E1 mean on my sharp a/c
It is a clean filter message. make sure filter is cleaned and reset as follows:
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
Sep 14, 2014 | Sharp AF-S120FX Air Conditioner
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 WHAT DOES MEAN
E-1- Indoor room temp sensor defective. Replace it.
Jul 29, 2010 | Sharp AF-S120FX Air Conditioner
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
How can I clear E1 permently from my AC
1. unplug unit
Jul 30, 2008 | Sharp AF-S120FX Air Conditioner
Sharp AY-A249J air conditioner not cooling
Maybe get an electrician to make sure the voltage is not dropping to low at start up.
Jan 14, 2008 | Sharp AF-S120FX Air Conditioner
Sharp AF-S120FX Air Conditioner Logo
437 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
