Question about Mtd Heavy Machinery
I have a bolens chiper/shreder model no47028 5hp i am trying to fined a drum screen its the part that is in drum under the knifes
2 Suggested Answers
cargurudude
  • 26 Answers
SOURCE: stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Posted on Mar 04, 2009
Hi there, Please could you explain how to change belt on Whirlpool dryer, model AWZ3413? Many thanks.
I will also include a link to check out the routing of the belt
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 13, 2011 | Dryers
Trying to replace a broken belt and cant quite figure out how to put the new one on
Check out the belt routing at this website.
Installing the belt
facing down.
Please RATE me
Model Number is MDET236AYW and dryer heats up but does not tumble? Any suggestions? How much to repair?
I will include this link to show you the drum belt routing
Installing the belt
facing down.
Please RATE me
Jan 02, 2011 | Maytag MDE2301 Dryer
How do I remove the top of a Frigidaire dryer - model GLEQ642AS2
I will include the instructions for replacing the belt, it will include the top removal and also a link that you can click on the see the belt routing.
Installing the belt
facing down.
Please RATE me
Jan 01, 2011 | Frigidaire Dryers
I have a Maytag gas dryer model #LDG8420 and the belt broke. I need a diagram on how the new belt goes back on.
Go to this website and view the pictures of your dryer belt routing
Installing the belt
facing down.
Please RATE me
Dec 31, 2010 | Maytag Dryers
Put a new belt on a Maytag Dryer - Model # PYe2300AYW
Go to this website and they have pictures of the route of the belt.
Installing the belt
facing down.
Please RATE me
Dec 29, 2010 | Dryers
Try to hit the start button to dry and it wont do anything just makes a low noise
Installing the belt
facing down.
Please RATE me
Dec 29, 2010 | Estate TEDX640JQ Electric Dryer
How do i remove motor from whirlpool dryer model LER5620KQ1
You will follow these instructions for replacing the belt, it will get you to the motor.
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Whirlpool LER5636P Electric Dryer
HOw do I change the belt on the Kenmore model 96281800 dryer
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Kenmore 63942 Dryer
Heavy Machinery Logo
48 people viewed this question
Top Mtd Heavy Machinery Experts
Tom Chichester
Daryl Gleaton
Bill Boyd
Are you a Mtd Heavy Machinery Expert? Answer questions, earn points and help others
