Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a Kitchen Aid KSCS side by side fridge. There is a little red light inside the Freezer part near the ice make on/off switch. It is blinking twice intermittantly. I cannot find what this means in the Manual. Ice making is slower. We did just change the water filter on the bottom of the Fridge. Thx
  • 146 Answers
SOURCE: kitchen aid superba fridge not cooling
Check your evaporator fan, defrost thermo., or defrost heater. One of these parts out are what causes ice to buildup on your evaporator.
Posted on Dec 19, 2007
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
catriver
  • 878 Answers
SOURCE: not working
Sanquinn, hopefully it's just the overload and relay. Remove the back cover in back by the compressor. On the left side of the compressor will be the overload and relay, connected to the compressor. If they are contained in a white casing, unplug the refer and remove it. Shake it and see if it rattles. If so that's probably your problem. This unit does have a electronic defrost board that could also be the culprit, but start with that overload and relay. You will save yourself a ton of money if that's whats bad. Easy fix. Post back and we'll take it from there. Catriver
Posted on Aug 10, 2008
  • 1214 Answers
SOURCE: no ice production
Chances are the fill valve at the bottom back of the refrigerator is clogged or failed. This valve opens to allow water to fill into the icemaker.
It could also be that the fill switch in the icemaker has failed, or depending on type of icemaker, the ice level bar is flipped up, or the mold heater sensor has failed.
Please provide the refrigerator P/N for more information.
Posted on Jan 15, 2009
  • 14 Answers
SOURCE: DRIPPING SOUND MAYBE POPPING ALMOST
This is normal operation, every 8 to 10 hours the heater in your freezer section turns on to defrost ice and frost from evaporator coil, this melting water hitting the heater is what is making popping and hissing noises.
Posted on Jan 20, 2009
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
KITCHEN AID KSRG25FKBL17
if you mean the one on the inside right hand wall of the freezer that is by the on off switch then that is normal push the flap in and make sure you arent blocking the beam and the light will go steady this is normal it means the optics are functioning as they should
May 08, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Apr 12, 2008 | Refrigerators
Kitchen Aid Fridge
how long does it take for fridge to cool if its not been used in months?
Nov 23, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
46 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
