Question about Ovens
I have a diplomat adp3553 fan assisted oven. There is no temperature control, I switch on at 50 degrees and the temperature just keeps rising. I have been advised the thermostat has gone. Where can I get one and how much am I looking to pay. Can you also advise how to change this please. I live in the West Midlands area and have good maintenance skills
aborcass
  • 2651 Answers
SOURCE: Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Posted on Nov 27, 2008
  • 125 Answers
SOURCE: thermostat setting for bakers pride y600 oven.
Hi, those screws are for the calibration of the knob to the thermostat, so your calibration is correct. Most likely you will have to contact a servicer to check the calibration, and set you knob and plate where they will align with the actual temp again.
Hope that helps, and thank you.
Posted on Jan 05, 2009
SOURCE: Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Posted on Jan 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: i need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 28, 2010
SOURCE: My Whirlpool range oven is showing P5H error and
my oven give me a p5h error when I try to turn it on to bake
Posted on Mar 05, 2011
Replacing the grill element
Please watch this. thanks
Jul 06, 2016 | Ovens
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Oven shows an F2 flashing after self cleaning along with a beeping sound.
Hello there and thank you for choosing fixya
The F-2 error code Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Jun 29, 2011 | GE JKP15 Electric Single Oven
While baking oven starts broiling with no input from controller. f2 is displayed on screen
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
Sep 27, 2010 | GE JKP15 Electric Single Oven
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
E1 f2 error
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
Good Luck
Sep 05, 2008 | GE Profile JT912 Electric Single Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Missing manuel Code showing - F 2 -
hi,
F2
F2
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
Ovens Logo
82 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
