Sunforce 11260 Pure Sine Wave Inverter Logo
Posted on Aug 04, 2010
My Sunforce 2500 W inverter alarm randomly comes on and the short circuit output error code (o.5.b) even though I have no load connected. Happens maybe once every 8 hours. Also, when using the key chain remote the unit turns off and no error codes can be obtained from a shutdown. Is this normal?
2 Related Answers
Anonymous
  • 384 Answers
  • Posted on Jul 23, 2009
SOURCE: I'm considering buying a Sunforce 11260 2500W sine
Numbe one reason ...you can not afford it.
Anonymous
  • Posted on Nov 01, 2009
SOURCE: The Sunforce 2500 pure sine wave inverter displays
Went to a free website with industry professionals sharing their knowledge instead of signing up for more ways to spend what little money I have.
Why is my 2500 watt sunforce drawing power from my battery bank when not in use
The batteries are connected directly to the starting circuit of the inverter. If u don’t want it consume any power from the battery I would recommend an isolater switch between the battery and inverter.
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 • Cameras
1helpful
I am using 2500 cobra inverter .when i go to plug in extention cord led comes up ( OPP ) and and i do know what that stsnds for ? no power
Short Circuit Protection - OPP
If the
AC output of the inverter is shortcircuited
for one second or more,
it will shut down to protect itself.
The meter will flash as shown to
indicate Short Circuit Protect and
an alarm will sound.
To restore normal operation,
disconnect the short circuit and
turn the unit
Off and On again
using the
Power Button.
Current flowing down an unintended path, try a new extension cord
Cobra inverter powers up but no power and it flashes OPP
the OPP error is an indication that the AC load "output" is short circuit. Try disconnecting the AV load-device and attempt to try again. Use a lamp or other suitable to confirm that the inverter is pr is not working properly.
It is possible that the load (device) that you have connected either exceeds the inverters power rating or is in fact shorted and the inverter is working properly.
If the opp flashes with no load attached it is likely that the inverter has developed an internal failure.
Hope this helps?
1helpful
Can this model be used on the grid? If not, is there a sunforce inverter that can be used on the grid?
If you meant for the mains supply then it must be connected in series to the load so that in absence of power the invertor takes over and when there is power the supply takes over as it charges the battery.
So have this wiring done with the connection routed from the fuse box or main board.
2helpful
Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Kelly
Have recently purchased a Sunforce 11264 4500W true sine inverter, shipment pending. trying to find a view of the back side of it to determine the 12V service connections needed, PDF of manual indicates a...
Hi , i'm sorry but i dont really understand your question , assuming the current draw is around 45 amps then 2 /0 GA is fine , just keep your leads from your panel nice and short , the connection kits are sold by sunforce and there plenty of suitable connectors on the market
example link below
http://www.globalepower.com/Datasheets/BatteryConnectors/BatteryGlobal.pdf
Aims 5000w inverter
Try shutting down the load completely, then power up the inverter with no connected load. Then bring a little on at a time and see what happens.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Sunforce Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Sunforce Electronics - Other Expert? Answer questions, earn points and help others
