Question about Dyson DC21 Bagless Canister Cyclonic Vacuum
The Dyson DC21 power head keeps tripping out. The carpets in the house are medium to low pile. It even trips out over hard surfaces. Could it be the resistor in the power head is to weak or faulty.
  • 5 Answers
SOURCE: Overheating Dyson DC07
Many devices including this one have what's known as a thermal cut out.
It is there for obvious safety reasons and prevents the temperature in the locality of the cut out from exceeding a pre-defined value.
Some of them require you to press a reset button in order to switch the power back on and other types simply reconnect the electricity supply when the temperature returns to normal (safe) operating limits.
The Dyson DC07 has a thermal cut out located close to the motor and it is of the "self resetting" type.
If your vacuum cleaner switches off after a few minutes the most probable cause (there can be others) is the thermal cut out has operated.
The first and most important thing to do is to establish why it has operated.... If the airflow around the motor has become restricted then it will not be being sufficiently cooled and so it will have cut out correctly. However, thermal cut outs are often quite crude internally and it is not uncommon for them to start cutting out at too low a temperature. So...
Here's what to do...
(some tools may be required to complete the following so read the entire procedure before starting. Please note this is not an absolute guide if you need really foolproof step by step instructions... buy a manual! But this should help)
  • remove and thoroughly empty the dust bin (do not put it back yet)
  • remove and clean the drum filter to the right of the motor (right when looking at the front of the machine). (N.B. Never put this back if it is still damp)
  • remove the accessories from the upright section
  • withdraw the handle and separate it from the flexible hose (all of these and the following parts have a colored (commonly yellow) release tags/buttons/levers *** Never force anything!! ***
  • remove the flexible hose
  • remove the pipe union to the left of the motor
  • carefully lie the machine on its front (wheels uppermost) and remove the u-bend
Check all these parts for blockages/clogging before continuing...
There are now only two areas left that I know of which may cause further blockages. One is the "whole of life filter" located under the dust bin and the other one is inside each of those seven little cones (cyclonic chambers) at the top of the dust bin (root 8 cyclone is usually written on one of them). The following will require some tools and some common sense...
  • carefully prise the plastic disc up (the one under where the dust bin rests) use a flat bladed screwdriver or similar releasing it from the lug you can see at the front. Inspect the filter and replace if necessary (when replacing it you may find the original has been glued to the plastic lid - if so gently scrape it off )
  • If none of the above has revealed an obvious problem lets turn our attention to these pesky little cones... if you have ever vacuumed up any damp material these can become blocked. You will need a size 15 star drive (sometimes known as torx TX-15) screwdriver. I recommend you buy one with a shaft length of at least 70mm (you will need one this long if you are to access the thermal cut out later)
  • Place the bin assembly on a suitable dust sheet.. this can get messy!
  • remove the clear plastic outer bin
  • undo the three star drive screws at the top and partly withdraw the top ***careful*** you can not fully withdraw this piece. All we are doing here is creating a bit of limited access and "peer room" (before withdrawing the lid you may wish to peer underneath and for future reference note how the release rod is engaged).
  • now here you have to use a big dollop of care and common sense. By peering into these cones (shine a powerful torch through the sidewall of the cone) see if you can tell if any of them are blocked.
  • using a small piece of wire or similar gently poke any blockages away. Be careful not to damage the loose but still attached lid.
  • reassembly is a bit tricky because you have to re-engage the release rod at the bottom whilst at the same time pushing the lid back into position. Take care not to damage or trap the large rubber sealing ring as you press the lid home Finally replace the three screws being careful not to over tighten.
If none of this revealed anything very positive... Its time to open up and inspect the motor casing/thermal cut out.
**** WARNING**** The next section requires someone who is technically minded, has fiddly fingers patience and a basic understanding of typical plastic goods assembly techniques. As I am not including photo's the descriptions given can only be considered as pointers to how to do it (I'm not writing a Haynes manual here! So if you are a cak handed clot with little or no patience and a tendency to resort to ever bigger hammers - take the vacuum cleaner to an independent repair shop - explain the symptoms, tell them what you have done so far and leave it to them!!
  • In order to release the roller brush and belt mechanism turn the vacuum cleaner face down undo the three 1/4 turn screws and carefully withdraw the grey plastic cover (ease the belt guard section gently away)
  • coax the belt from the motor end then withdraw the belt and roller from its housing
  • Now we need to release the mains cable from the switch area to the motor housing - Undo the screw below the yellow switch
  • Working from the back prise the plastic housing forwards (this is tricky) leaving the switch in the on position can help but the main lugs stopping the housing from coming forwards are at the top just behind the big yellow switch button. the best way is to insert a fairly small flat bladed screwdriver in past the upper lugs at the back and put a slight outwards force on the housing tou are trying to remove... patience! Repeat for the other side
  • Now undo the electrical connections and release the flex from its channel so it is free to be withdrawn when you release the motor housing
  • turn the vacuum on to its front and remove the four torx drive motor housing securing screws (two of these are down a fairly deep recess)
  • carefully withdraw the complete motor assembly from the shell
  • The remaining part of the grey plastic casing can now be removed (a bit fiddly)
  • You should now have the complete motor assembly housed in a black plastic case with the grey intake at one end. Inspect this carefully and you will see that the grey intake is held in place with four lugs. gently prise the black plastic over these lugs and the grey intake will come away
  • Now you need to do two things in stages - pressing on the shiny metal motor shaft will push the motor out of the black casing but make sure that at the same time you feed the mains flex complete with rubber boot through the hole.
  • Voila the motor is now exposed
  • Inspect the motor for any signs of overheating or damage - check the brushes are OK (if you don't know what these are and you've got this far, now may be the time to ask a friend with a bit more knowhow to help!)
  • Unplug the electrical connections and undo the small Phillips screw holding the plastic assembly to the motor casing (this contains a capacitor and firmly pressed against the metal motor casing is the thermal cut out
  • If all else seems OK replace the thermal cut out with a new one and reassemble
  • No I'm not going to explain how to do that! For the most part just carefully reverse these instructions! - come on you've made it this far!!
NB. NEVER remove or bypass the cut out. this really could be very dangerous!
I hope this is of some help... Regards to all.
Posted on Sep 30, 2008
galati2k
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
  • 10865 Answers
SOURCE: Is there an adjustment on Dyson for high-low pile.
yes there is an adjustment called a power cam. I am enclosing a link to show you exactly where it is
http://www.dyson.com/homepage.asp
Posted on Jun 25, 2009
Dysonteam
  • 167 Answers
SOURCE: dyson power head stops
Hi its Darran at Dyson.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
  • 183 Answers
SOURCE: Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Posted on Jul 28, 2010
We had an older dyson vacuum that worked great until it had to be replaced and now our new one it works great on short carpet but is very difficult to push on thicker carpet.
Hi Ronnie, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your new Dyson vacuum on this particular type of deeper-pile carpet. It's possible your new machine has higher suction at the cleaner head, and this could mean it needs slightly higher push-force on certain carpets with deeper, denser pile, or thick underlay. You may find it helps to use the vacuum with the brush bar switched - carpet manufacturers will sometimes advise vacuuming deep-pile carpets in this way.
However, I would encourage you to get in touch with us directly so we can take some further details about the issue. When you have your Dyson vacuum easily to hand, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to discuss your concerns.
We'll look forward to speaking with you.
Jun 03, 2015 | Dyson Vacuums
Is there a Dyson vacuum that Will work on high pile Mohawk carpet?
Patty,
I am not sure about any of the Dyson vacuums being able to handle that carpet. I work at an Oreck store on the weekends and I know that we have had several customers come in with the same question as yours and we recommend the Oreck Magnesium RS or any of the Miele vacuum cleaners. They have been tried out on Mohawk carpet and have been found to work well. Hope this helps!
Apr 16, 2015 | Dyson Vacuums
Why does my kirby shake ?
If your Kirby is just sitting on a hard surface and is shaking, something is either on the fan or brushroller putting it out of alignment. Here is how to change the fan / impeller if broken.
how to change Kirby fan / impeller.
If it shakes while you are pushing against the carpeting you can try adjusting the height of the brush until it is just touching the carpeting. Some thick pile carpeting the Kirby will still shake or jump on, the strong suction causes it to trip over the thick pile that is lifted up when vacuuming.
GoodVac.com
www.goodvac.com
1-800-775-6586
Oct 05, 2014 | Kirby Vacuums
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
When i set it on carpet instead of bare floor it is hard to push when i vacume (when i turn nob it only has two settings floor and carpet no high pile or low pile)
Sorry to hear you're having difficulties using your DC14 on this particular carpet. You may want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Aug 12, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My purple Dyson Animal (without the ball) isn't working correctly. When I turn it on, the red power light, as well as the medium pile buttons flashes. When I first turn it on, the brush rotates for 3 to...
I need help repairing my Dyson. I cannot push the buttons down to select Short pile/Medium pile or bare floor. The buttons will not push down at all. It will not allow me to select anything. I have very short pile carpet so it does not pick up that well.
Oct 23, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Dyson DC21 Bagless Canister Cyclonic Vacuum Logo
512 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
