Question about Refrigerators
Kenmore SxS fridge Mod# 10652559100 fridge side getting warm/ I replaced the evap mtr./ bi-metal defrost it seemed to work for a week and now the same thing. could the freezer micro-computer (part 4389102 ) or control micro-computer (part 8201527 ) be the problem? Also having a problem with the water/ice dispenser, sometimes it works sometimes it doesn't?
    Brigadier General:
  • 3,513 Answers
Hi
When a fridge/freezer runs, the condenser (all the tubes at the back) will get warm-hot. That is where the heat goes from inside the fridge. You need to check few things…
Are there excessive heat to remove from the fridge/freezer?
Check the door seals are ok - cold air falling out of a bad door seal can make a fridge both cool and warm a room at the same time - which obviously leads to problems
Check that the lights inside actually go off when you close the door by pressing the switch that the door usually presses when it shuts, and checking that the door will press the switch as far as it needs to go.
Secondly check that there is adequate ventilation at the back - remember the ideal situation technically for a fridge is to have the bit at the back outside the house in the shade like an air-con unit. pull the fridge a bit more away from the wall and try blowing a fan onto it. Clean gently with a soft brush any dust etc that is on all the tubes at the back - it can cause an insulating coat to form. If the dust is sticky and hard to shift, then gently use a soft paintbrush and warm soapy water.
Next is when the amount of refrigerant gas in a fridge system is getting low (they all leak a tiny bit all the time - even without any fault)
two main things happen:
The fridge gas has a lubricant mixed in with it that keeps the inside parts of the system oiled. when the gas is low, so is the oil and you get the same effect as running a car with no oil - runs hot, then dies.
The low gas has an effect inside and outside the fridge - inside, near where the gas first enters the evaporator (the plate in the fridge that gets cold) it will get extra cold. the compressed refrigerant evaporates too quickly - easy way to explain is that there is nothing in front of it in the queue so it runs through too quick. the same thing happens in reverse when the gas goes into the condenser at the back, the gas condenses too quickly making the back very hot.
Lastly you need a repair person to consult with.
Also the ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs. However check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
Samsung bi-metal defrost thermostat
most refriderators have an evap tube on the back of the fridge over time this will get all gummed out and will not allow the water to evaporate cause it to freeze try unclogging this tube with a pen or pencil go slow however you dont want to damage internals by jamming the pen in there hope this helps
Feb 22, 2014 | Samsung RS265LBBP Side by Side...
I have a Daewoo ERF-334M fridge/freezer and the auto-defrost has stopped working. The evaporator gets covered in ice within about 3 weeks from it being manually defrosted. I've checked the resistance...
More than likely if your fridge has a bi metal, or a defrost timer, its one of those two issues. Leaning more towards the bi metal. If the bi metal is encased in ice and is reading more than 0 ohms its your bi metal. (small round sick that sits on the tubing) Your heater should be reading around 25 ohms or something like that. it should be fine. If it does not have a bi metal it works on a thermistor and then you more than likely have a electrical control board issue that not forcing the fridge into defrost. Lmk if you need more help!
Aug 04, 2013 | Refrigerators
Freezer too cold, refrigerator warm
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 24, 2012 | Whirlpool Refrigerators
Kenmore side by side - 10653293201 - freezer frosting up so fridge gets no cold air through vents. Just had control board replaced less than a week ago.
The defrost is not working. Since you changed the board, I would say it is the defrost heater or the defrost bi-metal. You will need a volt meter to verify the solution.
Sep 22, 2009 | Refrigerators
Freezer & Fridge working, center pillion hot
Check the condenser fan from the back. It's underneath near the compressor. It should run when the compressor runs.
To see if your defrost is not working take the back off the inside of the freezer to see if there is ice buildup blocking the air flow. A light frosting on the enitire coil is normal
Jul 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Whirlpool Freezer
Most likely you have a defrost problem. IF, you think the timer is ok then the most likely problem is the bi-metal. That is a little part usually on the top right side of the evap coil and has two wires on it. If you can find the defrost timer and advance it slowly till the refrigerator stops running, then being in the defrost postion you can see if the heater is coming on. If so you have a bad timer. If NOT, then either the heater or the bi-metal is bad. Usually it is the bi-metal
Aug 27, 2008 | Freezers
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
