Question about Home
I WANT WIRING DIAGRAM FOR DIN RAIL TIMER SWITCH MODEL TM-848-1
SOURCE: Kenwood CD changer wiring diagram
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Posted on Jan 18, 2008
panilling9
  • 284 Answers
SOURCE: Wiring diagram for Sears Mower Model # 917.257562
sears.com
go to parts section enter your mod#
Posted on May 26, 2009
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Posted on Mar 20, 2011
oldTech2332
  • 2341 Answers
SOURCE: need color coded wiring diagram
what happened to the wiring diagram that was located inside of the control panel
Posted on Jul 23, 2011
How to connect a pool timer with a sul 181 h
Din rail timers and wiring appear following link:
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 01, 2015 | Hardware & Accessories
How to wire a theben 24hr timer
Generally theben timers are wired same as illustrations shown on following pages
Wiring varies slightly by exact model number.
http://waterheatertimer.org/How-to-wire-DTD-1440-timer.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
Most these timers are rated 15 amp.
Safe maximum :: 15 amp x 80% = 12 amp
230V x 12 amp = 2760 watt
For best long-term result, use timer to turn on a contactor (relay) and let the contactor handle switching heavy amp load
Fuse-protect the timer by adding inline fuse to hot wire going to timer.
Gene
Jul 14, 2014 | General Electric GE 24-Hour Timer, 2-Pin...
How to program CLS Q 31 D TIMER
CLS Q 31 D timer is ordinary 50-60 Hz 24-hour din-rail analog timer; rated 15 amp, operating voltage 230v with power reserve and 30 minute time increments.
15 amp safe max is 12 amp x 230V = 2760 watts. Use line fuse to protect timer from overload. Use contactor for heavy-amp loads and 3-phase loads.
Copy following links for setting analog timers and wiring din rail timers
http://waterheatertimer.org/How-to-set-timers.html
Add a comment and describe application for this timer
May 18, 2013 | Hardware & Accessories
Need user manual for THC15A weekly programmable timer
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Din-rail
Add a comment and describe timer buttons.
Apr 22, 2013 | Sourcing Map THC15A Digital LCD Power...
Onesto timer switch pts20a programing details
PTS20a is 20 amp version of Onesto din-rail mount7-day digital timer:
http://www.onesto.cn/product_list.asp?id=386
If you're searching for product manual, then there is no product manual posted oct 2012.
If you own this timer, then describe the buttons, and I can locate same-similar timer based on that description.
Frankly the product looks very similar to Intermatic Talento 400, or Tork DIN rail series.
But usually, to avoid patent conflicts, the Chinese knock-off product will have one or more button that is different.
Even with small difference, the programming will follow similar pattern, since all these timers do the same basic job.
Copy following links to help identify possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Talento-400
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DIN
Oct 04, 2012 | Hardware & Accessories
HOW I INSTAL ,CONNECT SWITCH TIMER TE502 ? IT
Wiring diagram shows on side of timer and looks same as to following illustration:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
For more complicated illustration showing din rail and modular timer wiring variations:
http://waterheatertimer.org/images/NO-NC-timer.jpg
With din rail timers, the power connects to screw terminals 1 and 2 and this will run the clock and relay.
The TE502 image is bad, and I can't see wiring diagram exactly.
It appears that terminal 4 is common. This is typical for din rail timers.
Put Hot lead to terminal 4.
Terminal 3 appears to be the NO terminal, so put wire going to Load to terminal 3.
Jun 20, 2011 | Electrical Supplies
How to bypass mtd8
To permanently bypass the timer, you have to move wiring.
I don't have specific wiring diagram or programming manual for mtda8 timer, but am familiar with wiring din-rail mounted digital timers.
1) Wiring is typical across all din-rail timers, with variations of same theme depending on number of channels and purpose.
2) Open following illustration of wiring:
http://waterheatertimer.org/images/DIN-series-wiring-300.jpg
Same-similar illustration shows on side of timer.
3) Notice the mtda8 has 5 screw terminals.
4) Two screws are for incoming power. These terminals are usually labeled 1 and 2. These wires power the timer.
5) Three more screws are for the timing relay. These screws are usually labeled 3 4 and 5.
Typically the #4 center screw is common, and carries power. And when timer is ON, power is live between #4 and #3 terminal. When timer is OFF, power is live between #4 and #5 terminal.
6) Move #3 wire to #4 or #5 screw and then the timer function is bypassed.
Jun 15, 2011 | Hardware & Accessories
Home Logo
353 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
