Hello! I have a Dell Inspiron 1501. When I turn my laptop on I get a black screen that's has PXE-E61: Media test failure, check cable. What does this mean and how do I resolve this issue?
  • 11,800 Answers
It means that the hard disk has died. Replace it and reinstall Windows.
Posted on Aug 04, 2010
I have the same problem. In my case, my computer boots up and works fine. However there is no sound. I just had service from Dell and believe instead of a hard disk failure, it is referring to the speakers not being connected to the mother board. Or where ever they are supposed to connect. Hope this helps.
Posted on Aug 08, 2010
Dell inspiron mini wont boot, screen says pxe-e61: media test failure, check cable, pxe-m0f: exiting pxe rom. And operating system not found. What do I do?
This is because the Bios doesn't find where to boot from and it tries to boot from lan. Take out the hdd, put it back and try again. Try also with another hdd. Check the bios to see the boot order. Post here results !
Apr 15, 2013 | Computers & Internet
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
Operating system not found
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 22, 2012 | Dell Inspiron 910 Laptop/notebook Black
When I turn on the Mini laptop, what does this mean: Realtex RTL8101E/8102E PCI-E Ethernet Controller v1.08 PXE-E61: Media Test Failure, check cable PXE -M0F: Exiting PXE ROM Operating System not...
media test failure like above while
booting means that the problem already solved as long as you can get
into Vista/win7/xp as usual. PXE shown in the massage is
the Ethernet network boot option which you’re not using. There are 4 options you can use for boot up the laptop:
1. Network
2. DVD/CD
3. USB Storage
4. HDD
That was better to use HDD unless you are connected to a LAN then you need to change it to Network
Aug 31, 2010 | Dell Inspiron Mini 10 Notebook
My kids dropped it and the Boot report says PXE-E61 media Test Failure, check cable, initially I did a F12 system boot report and it said failure to read hard drive, i took it out put it back in , looks...
You should go to dell.com, support - you can type in your model and look up troubleshooting the wireless card and fix it from there, including downloading or updating drivers.
Apr 06, 2010 | Dell Inspiron 1501 Notebook
PXE-E61:MEDIA TEST FAILURE PXE-M0F:EXITING BROADCOME PXE ROM
hello, sounds like bad hard drive. here is what you can try, go in to BIOS and reset it factory default save and exit, let the system start again go back in BIOS and check to see if you see your hard drive there, also this time disable Boot from Network option. seeif your system actually starts up... or you get "no operating system found", if you saw the HDD in BIOS and get no operating system found, you can try reinstalling windows.
if you still media test failure and it loops, you need a new hard drive.
let me know if it helps...
good luck
Amar Sondhi
Dec 03, 2009 | Dell Inspiron 1501 Notebook
Pxe-e61: media test failure, operating system not found
First, take out any CDs/DVDs and try to boot again. If that doesn't work, your hard drive may be defective.
There will be a cover on the bottom of your laptop that holds the hard drive (easy access). You can try removing and reinserting the hard drive and then booting the PC afterward.
If that doesn't work, you will likely have to replace the hard drive, but best advice would be to take it to a computer technician for further analysis.
Sep 02, 2009 | Dell Inspiron 1501 Notebook
My niece's Inspiron 1501 doesn't boot at all. The Dell splash screen comes up and goes to what I assume is the BIOS Screen that then displays the following error codes: PXE-E61: Media test failure, check...
It is also possible that the cable to connect the hard drive to the computer has gone bad or disconnected itself. This can sometimes happen in laptops. Try checking your hard drive using the system diagnostics in the BIOS settings, or by creating a Drive Fitness Test CD on another machine (http://www.hitachigst.com/hdd/support/download.htm). If neither of these detects your hard drive, it's very likely a connection issue. If you feel comfortable doing so, and it doesn't void your warranty, you can unscrew the cover on the bottom of the laptop and check the connection yourself. Make sure you're grounded, so you don't ruin anything with static discharge. If you don't have a screwdriver that small you can usually get one of those kits at the dollar store. They're the right size, but be careful because they will sometimes strip the screws. Good luck!
May 16, 2009 | Dell Inspiron 1501 Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Computers & Internet Logo
161 people viewed this question
Alun Cox
David Payne
David Payne
