Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Vista sound output problem
I have connected Logitech 5.1 surround sound speakers but can only get quad sound out of them. The centre spkear and sub woofer are not being recognised even though I have them set up as 5.1 in both Windows Media Centre and in the Realtek set up.
Its pretty frustrating can anyone offers help please?
  • rubbaa Aug 17, 2008
    i have an echo with the sound
  • Tom Kilroy
    Tom Kilroy May 11, 2010
    Do you have 5.1 surround sound soundcard? Does it have ports for center rear and sub?
Actuly i install window vista .but noe my sound card no working
Posted on May 30, 2008
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
My a102jamo surround sound speakers and working
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Aug 31, 2014 | Audio Players & Recorders
Logitech X-530 speaker set plugged in as per instructions delivering sound from only front speakers and sub woofer. Nothing from centre and rears. XP system with ASRock ALiveDual-eSATA2 mother board....
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
Aug 08, 2017 | Logitech X-530 5.1 Surround Sound...
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I have the X-540 Speaker system set to 5.1 surround sound. By testing it on Windows Vista Home Premium x64 I have concluded the center speaker does not work when all others do including the sub...
Have you tried adjusting the matrix settings on the speakers. Try pressing the matrix button on the control box and see if that resolves the issue for you.
Robert from Blitware
Jun 17, 2010 | Logitech X-540 Computer Speakers
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
How does Logitech X-540 speakers connect to a laptop?
You connect the green cable from the subs (the green one of the three, the other two being black and yellow) to where your headphones or speakers go into your laptop. Then you make sure the matrix button is activated on the x-540. This will make sound come from all of the speakers and it will use the sub, i.e. virtual surround sound.
To do it properly without using the matrix mode and trying to enable actual surrond sound (with centre satellie being mostly vocal, front two being instrumental/music, and back two being sound effects) then you need to buy an external sound card for your laptop that supports 5.1. I'd recommend the creative x-fi external usb, but only if you have xp. If you have vista, forget about getting an external sound card that supports real 5.1 for now because there aren't really any good and truly compatible ones.
Jul 08, 2008 | Audio Players & Recorders
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
93 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
