Question about RTO 2 Siemens Pure 700 Open Fit Hearing Aids Aid Ric Bte
I have Pure 700 RIC BTE HAs for 14 months now. I have had 8 repairs to date. Seems any perspiration ruins the amplifier. I keep them in a drier overnight. I paid a lot of money for them and they are " In the shop " every 5 or 6 weeks. My Audi is going to extend the warranty to 4 years but if this were a car, I would get my money back because of the Lemon Law. Is this a common problem with Siemens? Are other brands so sensitive to perspiration?
    Problem Solver:
  • 11 Answers
It is a common problem, Siemens do seem to suffer it more though. Your audi should keep receivers on hand in order that he can fix it on the spot. Keep your ears clean and dry, clean and dry your aids every night. The use of a drying kit is ideal, but make sure you are changing your tablet enough or re-charging your crystals in the microwave, whichever it is.
Posted on Sep 19, 2011
My Pure 700 aids just started to beep continusly for awhile then shut down. I can turn them back on and they will work for awile and then start again, changed batteries with no help. Looking for possible...
Intermittent issues like this can be moisture issues, it might assist if you use a drying kit every night. Another issue could be if you are using the rechargable batteries and charger that may have been supplied to you. After a year or two those batteries will no longer hold a full charge and will need to be replaced.
Could you clarify this for me?
Sep 04, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
I replaced the batteries in my Siemens Pure 700 BTE but the hearing aids do not work. I tried several sets of batteries of different manufacture but they still do now work. The worked just fine until the...
If indeed you are, you need to take them back to the Audi, he will need to assess whether the receivers have failed or if for some reason the instruments have failed.
Aug 01, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
How to clean the domes on hearing aids
Take the domes off, wash them out or use a pipe cleaner to poke out the wax. If you have washed them, make sure they are thoroughly dry before you put them back on. When you put them back on make sure they are firmly on the receiver tip or you will be taking a trip to A&E to get it removed from your ear canal.
Jul 20, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
R. Hearing aid has died for the 5th time. Purchased through HearX.
RIC instruments are quite delicate, the receivers often fail, however it is a quick fix to replace them. Have you tried a drying kit, a drying kit is essential to maintain RIC or RITE instruments particularly during the summer months. Go back, get the receivers changed and ask for a drying kit.
Jul 08, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
Siemens charger for hearing aids starts charging and then after some hours one light goes red
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
May 03, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
It's exactly like the guy says on the left: Siemens Pure 501 RIC Serial No RW52119 The above unit is in the right ear and periodically does not produce any sound. The RIC cord has been replaced once and...
The receiver, the piece you call the cord is either blocked with wax or dead. Check the very tip of the receiver for wax detrius, if there is some remove it and see if you can hear. If not you may need to get a new receiver.
Apr 20, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
Siemens Pure 501 RIC Serial No RW52119 The above unit is in the right ear and periodically does not produce any sound. The RIC cord has been replaced once and still the problem persists. Pushing...
It could be a receiver issue, the cord, it might be a faulty receiver or alternatively it could be plugged with wax or badly affected by moisture. Receiver issues are relatively common with Siemens, if you have cleaned out the tip and are confident it is not a moisture issue, the receiver has failed. it is an easy fix and your audi should be able to change it out on the spot.
Apr 16, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
I find that my BTE open fit hearing aid solves a lot of problems but the fitting seems to creep away from the ear drum making it difficult to hear. I find I am continually pusshing the tube back to where...
There are a couple of solutions that you can try, ask your audi to fit a sport lock or change the tip he is using. If that does not work, think about investing in a set of custom made tips. A sport lock is a piece of plastic that attaches to the tubing, when you place the tip in your ear this piece of plastic is folded around the inside of your outer ear along the bowl.It aids retention of the tip.
Mar 11, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
Can come out when i remove glsses or take off jumper or hat
Hi Jan3630,
The instruments you show in the picture appear to be ear inserts rather than custom ear mold. Customs can also be small.
You may consider having a local Hearing Health Care Professional advise you as to the feasibility of replacing your sound tubes and inserts with Custom ear-molds.
These will have a better chance of staying in the ear when you are doing the activities you described. Please advise if you find info helpful. Thanks for contacting FixYa.com
Oct 27, 2009 | RTO 1 Siemens Pure 500 Open Fit Hearing...
RTO 2 Siemens Pure 700 Open Fit Hearing Aids Aid Ric Bte Logo
546 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
