Question about Sport & Outdoor - Others
IntelliChlor POOL SALT CHLORINATOR control panel; SALT salt level -blinking yellow STATUS power-is red cell-green blinking green flow-green Could low salt a reason for red light? cleaned the generator w/ hose no calcium build up. All other lights okay.
SOURCE: Aqualink Chlorine Generator not producing any chlorine
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Posted on Aug 04, 2009
  • 16 Answers
SOURCE: no light on cell status on my chlorine generator
What brand of salt water chlorine generator do you have?
Have your water tested professionally at a pool store. Balance the pool water chemistry. Check the electrolytic cell for any calcium deposits on plates and follow manufacturer's instructions to clean.
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: My Goldline Aqua Pro control panel says "no cell p...
See on www.manulabo.com/hayward to have your solution
Posted on Jul 06, 2010
thepatioman
  • 52 Answers
SOURCE: Can't adjust the chlorine output level of Zodiac LM3-15
Nost often it just needs to be cleaned. Calcium build up can clean in a tub of 1 Part muratic acid to 5 parts warter. or a 2 to 1 soultion of vinigar and water, otherwise it could be faulty. Cleaning typically works.
The Pool Tech
Posted on Jul 14, 2010
  • 297 Answers
SOURCE: We have a 15' by
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Posted on Aug 31, 2010
Zodiac lm3
The lm series chlorine generator has a tri-sensor inside the cell that measures flow, water temp, and salt level in pool. If the controller is indicating no flow after it has been cleaned properly, then the cell is most likely in need of replacement.
Jan 06, 2014 | Zodiac Lm3-24 Salt Water Chlorinator...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
Green light will not come on chemicals are fine
You may have a chlorinator cell that needs cleaning. I usually use muriatic acid diluted 4 to1. Find something you can submerge the cell in and be careful of the acid. If this doesn't help then there is probably something wrong with the cell or the control box.
Happy pool management.
Aug 07, 2009 | Intex Automatic Salt Water System for ...
I have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
DuoClear 25 doesn't chlorinate well, chlorine output lights
have water checked see if chlorine is locked that will act like chlorinator not working also crack output union so water drips out test with strip if chlorine oxidize water if no chlorine unit not working
Jun 12, 2009 | Zodiac Duo Clear System Chlorine...
No light on cell status on my chlorine generator
Mar 18, 2009 | Pool & Spa
Sport & Outdoor - Others Logo
153 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
