Question about Bosch WFMC2100UC Nexxt Essence Washer
Hi, my 5 year old Bosch washer has started making a noise when it's on the slow side to side spin (not fast spin). It's a periodic creaking noise that occurs when the tumbler is in motion. The noise goes away when the tumbler goes to the fast spin. Any ideas?
Mine also sounds like it has that problem. it's almost like a squeaky spring and the more weight in the tub the louder it sounds....but only on the slow tumbles. i just had the cold water inlet value replaced last month and just last week it starts making that odd sound. so i just had a repairmen come look at mine. he said it sounds like a "normal" sound and noticed it happened when the direction switched. he said he would have to take the entire thing apart to try and find the "problem" (could be the belt, suspension, etc.) but couldn't guarantee he could find nor fix it. (he also didn't think it would have been caused by the leak) i'm clearly not satisfied with that answer (which is why i'm trolling around looking for others who have this problem). i think i'm going to get a second opinion. i could update you on that if you find this information relevant.
Posted on Oct 05, 2010
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Our frigidaire 10 year old front-load washer is vibrating way too much. it knocks on fast spin. is something broke?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 12, 2011 | Frigidaire Washing Machines
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
Washer Problems
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Kenmore front loader model 417.29042992
check and make sure the washer is LEVEL otherwise when in spin, it may "walk" across the floor. also if it's not level then the tub will "tilt" in one direction and may contribute to the thump, thump.
Aug 23, 2007 | Kenmore 43042 Front Load Washer
Ticking/chirping sound during slow spin
it will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
Aug 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
193 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
